Can not shift truck from park to drive
Discussion in 'General Tundra Discussion' started by Tracker2, Jul 12, 2020.
  1. Jul 12, 2020 at 12:26 PM
    Tracker2
    Tracker2 [OP] New Member
    2013 toyota tundra
    My power outlets in my 2013 tundra were not working. Yesterday I changed out the fuse and now they work.
    However, today when I started my truck. the truck shifter was locked. Also the ABS light is on, The parking brake light is on, the underinflated tire light is on and the air bag light is on.
    I am assuming that in searching for the right fuse for the power outlet I have screwed up something else.
    Any help?
  2. Jul 13, 2020 at 6:31 AM
    Gotyour6
    Gotyour6 New Member
    Fairport, NY
    2019 Tundra Pro
    May want to check the brake sensor
    Not sure about the other lights though.
    You can override the shift on the console to go into drive
  3. Jul 15, 2020 at 11:36 AM
    TundraGuy68
    TundraGuy68 New Member
    Its likely a loose fuse from you searching for the blown one, or a low / bad battery .
    goffredo likes this.
