Can it be that simple?
Discussion in '2nd Gen Tundras (2007-2013)' started by RegimeChange, Aug 18, 2024.
  1. Aug 18, 2024 at 1:21 PM
    RegimeChange
    RegimeChange [OP] New Member
    13 Platinum Crewmax
    Muffler delete.
    I have a 2013 Platinum Crewmax with the TRAC OFF light on, and 4LO blinking. Its showing me the following codes: P0121, P0123, P1604, P2135.
    The 121 and 123 codes apparently are history codes. The 1604 is "Starting issue"... which to me is quite obvious. My engine cranks fine. Will not fire up.
    The 2135 is the pedal sensor. Seems like an easy replacement if that is in fact all thats wrong.
    My wife was driving it to the store. On her way back she had no acceleration. Engine ran fine. She shut it off, came and got me. When I went out there, I could not get it started.
    Ive cleaned the throttle body. Even toyed with closing and opening the butterfly valve by hand. (If I hold it closed, it stutters like it wants to start but it doesn't.) Upon releasing the butterfly it dies immediately and just goes back to cranking.
    Which said codes and warning lights on dash, could it be the pedal itself?
    And would that even cause a "No Start" issue?
  2. Aug 19, 2024 at 9:26 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Does it have gas?? my fuel needle stops at a 1/4 tank full, so I try to fill it back up well before that... another troubleshooting method is jumping the relay, see if it starts that way.
    RegimeChange[OP] likes this.
  3. Aug 19, 2024 at 9:33 AM
    Yes, it could be that simple.
  4. Aug 19, 2024 at 10:19 AM
    RegimeChange
    13 Platinum Crewmax
    Muffler delete.
    I filled up the day before. Drove it home. Wife drove it 2 miles. So still (practically) a full tank.
  5. Aug 19, 2024 at 10:20 AM
    RegimeChange
    13 Platinum Crewmax
    Muffler delete.
    The pedal failing could cause a "no start" condition though? Wth kinda truck is this? Never heard of such a thing. Although, this is my 1st vehicle thats drive by wire. Every other vehicle Ive owned had a physical cable that pulls the butterfly open.
  6. Aug 19, 2024 at 10:48 AM
    No more carbs, no more plug wires. These are modern computer controlled machines. They run through a series of checks at startup and a number of things can prevent a start. Sensors, controllers etc. The gas pedal is not a pedal any more, it's a switch that tells the computer how much and when. If the switch fails, the computer doesn't know what to do. Is this your trucks problem? Not sure that's the case, but it warrants looking into.
  7. Aug 19, 2024 at 11:46 AM
    apwisher
    apwisher New Member
    Everett, WA
    2007 CM SR5/TRD 4x4 White
    canopy, TRD Sway, audio
    you might try disconnecting the battery for a few minutes and reconnecting. It may fix the the no start issue enough to get home.
  8. Aug 19, 2024 at 2:14 PM
    RegimeChange
    13 Platinum Crewmax
    Muffler delete.
