Can I use 295/65/20
Discussion in 'Wheels & Tires' started by DM 2018 Tundra, Jan 4, 2019.
  1. Jan 4, 2019 at 1:46 PM
    DM 2018 Tundra
    DM 2018 Tundra [OP] New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    Hey I am new here. I did a lot of research on trucks and picked up my 2018 Tundra. I ask for some help last month on lift ideas and with everyone info I have ordered a 6 inch RC lift with new struts up front. So now here is my other question I have a set of 295/65/20 Nitro Ridge Grappers. Can I run thesewith a 6 inch lift?? Also I am going to get Fuel Rims but don’t know what off set to get so the want rub. Any help please? Thanks and sorry for my stupidness.
    OR18TRD likes this.
  2. Jan 5, 2019 at 6:45 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    Lol ok I get one.
  3. Jan 5, 2019 at 6:51 AM
    DM 2018 Tundra
    South Carolina
    2018 Limted Tundra
    I just put tow mirrors on it. Lift is setting in the garage until I find what rim offset to run.
  4. Mar 14, 2020 at 4:18 AM
    Paxrom
    Paxrom New Member
    2020 Tundra SR5
    Leds
    Running Nitto Ridge Grappler 295 65 20. So issue will be where do you want rubbing. With stock tss wheel 20x9 +50mm, it will rub on the sway bar and front wind dam. Both of these can be removed. You do not need a cmc, infact the mud guard can be left in place. The upper control arm may or may not rub depending on your kit. I did a rough country 3.5 and it came with new control arm. About half inch of clearance from the new UCA. It barely rub the front fender that it doesn't need to be removed just heat formed. This leave the sway bar. You can either remove the sway bar or find a shop that will fabricate you new one that is bent about half inch in, or run a different offset. Most guy that do +25mm will begin to rub the cab mount. You may want to try +40mm or even +35mm. it only rub the sway bar at about 95 percent from full lock on forward. In reverse it will rub at 75 percent from full lock. But these are going to be the true 35 in tires. If you don't want any rubbing or removing components stick to 285 65 20 using stock wheels.
    plumber802 likes this.
