Can I tow a 6200lb travel trailer Forest EVO
Discussion in 'Towing & Hauling' started by Zaner44, May 7, 2019.
  1. May 7, 2019 at 9:10 PM
    Zaner44
    Zaner44 [OP] New Member
    Zach
    2017 tundra
    So I just bought a travel trailer, but I’m concerned that I don’t have enough towing capacity to pull it safely. I have a 2017 crew Max 4 Wheel Dr. Model code is UPK56L-PSTSKA
    Says in the manual the GCWR is 12500lb and the TWR is 6400lb. Engine is 1UR-FE. Is this safe to tow, and should I add anything on to my truck for more safety. Thanks
  2. May 7, 2019 at 9:11 PM
    Zaner44
    Zach
    2017 tundra
  3. May 7, 2019 at 9:27 PM
    AZTundra likes this.
  4. May 21, 2019 at 11:06 AM
    shimloom
    shimloom New Member
    2016 Ltd crewmax
    I tow a 2014 F.R. EVO 2460 at just under 6000lbs. My 2016 CM LTD has a 10K towing cap. I do great with mine, pulls hill great. Have a weight distribution hitch and sway bar controller, should be good to go.
