Can I run both a TRD rear sway bar and airbags?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Aug 3, 2022.
  1. Aug 3, 2022 at 5:14 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    I am hoping to make my Tundra a comfortable towing machine. I already added the TRD rear sway bar, can I also add airbags and will they help or hurt or work against one another or make for a harsher ride?
    Moe2o4 likes this.
  2. Aug 3, 2022 at 6:18 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Yes you're good to do so...
    IowaGuy[OP] likes this.
  3. Aug 3, 2022 at 6:22 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Yep, I am!
  4. Aug 3, 2022 at 6:23 PM
    M3Tundra-JK
    M3Tundra-JK New Member
    Scott
    2005 GX470
    Ya man. Do it! I have sitting in my garage waiting to be installed, SOS Performance lowering kit, rear air bags, front & rear TRD sway bars. Can't wait to get them installed!
    Moe2o4 likes this.
  5. Aug 3, 2022 at 6:25 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Can you wear socks and shoes?
    Yes you can!
  6. Aug 3, 2022 at 6:26 PM
    M3Tundra-JK
    Scott
    2005 GX470
    Also air bags will only make the ride harsh if you air them up too much. Grab the Firestone in cab air compressor regulator for it, extra $250-300, and you can control the PSI from the drivers seat
  7. Aug 3, 2022 at 6:28 PM
    M3Tundra-JK
    Scott
    2005 GX470
  8. Aug 3, 2022 at 7:06 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Been there, done that. Skip the bags and go RAS. HD, black disk, in my experience, on E-rated .
    HulkSmurf14 and Saltyhero13 like this.
  9. Jul 14, 2023 at 6:00 PM
    Ipaddick
    Ipaddick New Member
    Canada
    Platinum hybrid w/advanced package
    If I have Airbags and AVS can I run the TRD sway bar? And what difference should I expect?
  10. Jul 14, 2023 at 7:41 PM
    blenton
    blenton New Member
    Unless you count sandals as shoes. In that case, the answer is no. Just plain and simple no. Uh uh. Nope. No way. Can’t do it. Flat out no.
    But the sway and airbag is a go. As for the Gen 3, I have no idea, but I would think yes since most coil spring rear suspension do well with a rear sway bar and come setup from the factory with such. If there’s one on there already, I don’t see why it can’t be swapped for a TRD model.
