Can I run 37s with this setup?
Discussion in 'Wheels & Tires' started by Rayota69, May 19, 2019.
  1. May 19, 2019 at 1:29 PM
    Rayota69
    Rayota69 [OP] New Member
    Ernie
    2015 silver tundra
    6 inch lift straight pipe bull dog programer
    Ok here goes. I have a 2015 tundra. I recently put 6inch suspension lift “rough country”. I have 18 inch rims 285/65 tire. I think a +24 offset I’m not sure on how the offset works, I ordered the rims to stick out 1 inch past factory, so my question is can I run 37 with this set up, do I need a different offset or just up grade to 35 the kit said I can run 35/12.50, but I would love to put 37. But I believe my outside cab mount may be an issue where it is mounted solid to the frame at fender wale
  2. May 19, 2019 at 1:43 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    I cant answer the offset/clearing question, but you'll want to regear for 37's and some do for 35's.
  3. May 19, 2019 at 2:07 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You can, you're offset is perfect. Lots are running that on 3" lift. Regearing isn't needed right away. It's your preference. Many running 37s without rehearing. Some have plans for it.
    Rayota69[OP] likes this.
  4. May 19, 2019 at 2:47 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Should be fine. If you have to trim a little nbd. Chop the body mount and push the front bumper forward with spacers
  5. May 20, 2019 at 8:27 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    https://www.tundras.com/threads/dirty-seven-club.40397/
    Read through this. It's gotten a bit long, but most guys who posted in there, myself included, are lifted 3" or less up front. In short, it can be done, the amount of trimming that is required will depend on primarily wheel offset and tire width.
    Wheel offset isn't complicated. Basically, it is the measurement in millimeters between the inside/outside center of the wheel and the surface that mounts up to the rotor. If that surface is closer to the outside of the wheel than the inside, your offset is positive, and your wheel will stick out less. Negative offset means that surface is closer to the inside rim of the wheel and your wheel will stick out more.
    Regearing is not necessary, but probably advisable on a 3rd gen. From what I understand, the throttle is a bit less sensitive than 2nd gens like mine. I personally like the smoother acceleration with 37s and 4.30 gears.
