Can I move my trailer springs?
Discussion in 'Suspension' started by Tracker, Apr 13, 2016.
  1. Apr 13, 2016 at 8:34 AM
    Tracker
    Tracker [OP] New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    So the crap pipe sometimes scrapes the curb as I pull out the trailer. I know from past reads I have done that this has been a cheap way to lift trucks. So can I place my leaf springs on the trailer above the axle? The trailer weights 6,500 I believe. Its a dual axle and I'm guessing I will get a 4-5" lift out of this idea and it will give me plenty of clearance.
  2. Apr 13, 2016 at 8:39 AM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    shouldnt be an issue to go SOA on there, looks like you'd need to just extend the bump stop pads if you did that though.
    Lots of guys do exactly this when towing behind lifted trucks to get the trailer up closer to hitch height. Might lose a bit of stability with the higher stance
    MotoTundra likes this.
  3. Apr 13, 2016 at 9:45 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I've only done this on a single axle, 3,500 lbs trailer to, like @Relentless mentioned, tow behind a lifted truck. The only thing that I might be concerned with is possibly some unforeseen handling characteristics, may become squirrely at highway speeds. No real basis for that though, just something to be wary of I guess.
  4. Apr 13, 2016 at 12:18 PM
    Check etrailer.com
    They have the spring over conversions for around 44.00 each.
    As others have stated, handling may be affected.
    Another route I have gone either trying to go up or down is tires. Can you run a taller tire?
  5. Apr 13, 2016 at 12:28 PM
    Tracker
    Shane
    I can, but two inches taller tire only gains one inch of clearance.
  6. Apr 13, 2016 at 12:52 PM
    You know what they say, an inch can save a marriage. Lol
    How much do you need?
    T-Rex266 likes this.
  7. Apr 13, 2016 at 12:59 PM
    DBL TAP
    DBL TAP Light 'em up
    USA
    Have you considered modifying the poop plumbing to gain clearance?
    If that's not possible, I would check with the TT manufacturer before lifting the TT. Good luck.
    ColoradoTJ likes this.
  8. Apr 13, 2016 at 5:00 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I was looking at the pictures again and noticed a pretty good crack in the tread of the tire. Something to add to the list.
  9. Apr 13, 2016 at 6:22 PM
    Lol. Holy shit, that is the Grand Canyon in your tire!
    I just purchase another spare tire for the TT. The old one is brand new, but in a LR D and I have Es on all my trailers.
    Discount has some pretty good deals on ST tires right now. I was out of the store with a LR E 225 for under 95.00.
  10. Apr 13, 2016 at 11:45 PM
    Tracker
    Shane
    Yes its on the list. All new tires and rims. The tires are crap.
  11. Apr 13, 2016 at 11:46 PM
    Tracker
    Shane
    The line is level with the tank right before the spout. Ot would be a major overhaul to modify it.
  12. Apr 14, 2016 at 12:04 AM
    What size tires do you have?
  13. Apr 14, 2016 at 12:19 AM
    Tracker
    Shane
    ST175/80R13
  14. Apr 14, 2016 at 12:36 AM
    Bummer, I was going to give you my extra spare that can't be used. Wrong size.
    Tracker[QUOTED][OP] likes this.
