Can I drive without my cv axles?
Discussion in '1st Gen Tundras (2000-2006)' started by ifox, Jan 5, 2021.
  1. Jan 5, 2021 at 7:54 AM
    ifox
    ifox [OP] New Member
    2001 tundra v8 4.7 4wd
    2.5 in lift kit
    Hi I have a 2001 tundra 4.7 4wd. I am traveling broke down in a random town, my front differential is grinding and seizing, there's one pick n pull I hope will have a front differential for it, but if not has anyone ever driven without your cv axles? I was thinking to tape up with aluminum tape the opening to the wheel bearings, and as for the opening to the front differential bearings I don't care about its already destroyed.
  2. Jan 5, 2021 at 8:03 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I think you need the wheel hub portion of it to keep the bearings and stuff all together
    Darkness likes this.
  3. Jan 5, 2021 at 8:03 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    You'd need at least the outer stubs from the CV axles to hold the wheel bearing together and remove the front driveshaft.
    Wynnded likes this.
  4. Jan 6, 2021 at 7:24 AM
    Pull the axles and front diff. Removing the front drive shaft from the transfer case to the front diff at the U-joints may work. Leaves the shaft end in the transfer case so fluid won't escape. Roll 2wd until the replacement can be sourced. I've not removed my front diff before, so not sure what that job looks like from a what needs to come out to remove it. I've replaced both front CV axles and that is a bit of a pain on it's own. Hope you have some shop access. We also need to hear the story of how you broke it, pictures of you landing the jump and a tape measure showing how deep the mud was. Thanks.
    BroHon, Glock 40, Cruzer and 2 others like this.
  5. Jan 6, 2021 at 2:08 PM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    You cannot drive without the CV axles installed. The torque from the axle nut is designed to hold the wheel bearings together.
    snivilous and KNABORES like this.
  6. Jan 6, 2021 at 7:43 PM
    So now you're down to replacing the transfer case now, or separating both ends of the CV axle from the axle shaft. That way you can leave the outbound side bolted to the hub to hold your bearings together.
    lsaami likes this.
  7. Jan 6, 2021 at 9:01 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    I can't really believe what I'm reading here. You are putting yourself and everyone around you at risk... You cant use speed tape to hold your truck together. Please don't be offended.
    cnoyes72 likes this.
  8. Jan 6, 2021 at 9:14 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I don’t think anyone suggested anything that will endanger anyone. However, towing home with a uhaul may be a better option.
  9. Jan 6, 2021 at 9:48 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    Not sure how far you've gone or if front diff was available at the junkyard.
    Cut both outer cv boots off and remove both axle shaft centers & inner CV's. Keep outer CV's in the front hubs. Remove front driveshaft to keep diff from turning.
    FrenchToasty likes this.
  10. Jan 7, 2021 at 2:07 AM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    2016 Black TRD CM 4x4
    Just sawzall the center part of both cv shafts if ur just trying to get home at all costs. Quick and easy, leave everything in place. It would free up the issues of the seizing third front diff. Obviously youd have to replace them later though.
  11. Jan 7, 2021 at 4:16 AM
    Professional Hand Model
    Hand Protectors
    New CV’s cost $900 (Toyota). Might be less to rent a uhauls.
  12. Jan 7, 2021 at 5:58 AM
    Believe the idea was to use the tape as a dust cover, not as a mechanical device. Cover the exposed bearing face to keep dust out. But we've since been informed that the CV axle hub to nut retainer holds the bearing assembly together or in place.
  13. Jan 7, 2021 at 7:54 AM
    vegas4x4
    vegas4x4 Blaaack
    Las Vegas
    CVs at rock auto are $48 each. Seeing that its an older truck id personally opt for aftermarket if i had to replace them.
  14. Jan 7, 2021 at 8:28 AM
    OP must have already been eaten by coyotes. Shame we couldn't save him sooner.....
  15. Jan 7, 2021 at 8:37 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    OP might not be able to get a full OEM CV axle assembly new from Toyota without waiting as they are on back order right now as far as I can tell. Full OEM assemblies are also pricey. With that being said I wouldn't sawzall and destroy the shaft; if it can't be towed disconnect the shaft from the CV joints and leave the outers connected to the hubs.
    KNABORES likes this.
  16. Jan 23, 2025 at 3:35 PM
    lancedal
    lancedal New Member
    Dallas
    Corinth MS
    2004 Tundra SR5 4.7 4x4
    Vehicle Modifications:
  17. Jan 23, 2025 at 3:41 PM
    lancedal
    lancedal New Member
    Dallas
    Corinth MS
    I have a similar problem with my 04. as my bearings in the transfer case for my inner cv axle are bad. I cut the cv axle off at the spline -the wheel end-and bolted that back on and tightened the axle nut, so the bearings stay tight ( as per responses mentioned)Sealed the bearing opening at the boot, sealing the open end.
    I do not need the 4 wheel drive here in MS. I have been driving it around town with no problem.
    I will need a need transfer case.. wrecking yards have them from $759-1200. If a shop does it it will be $3000 ish
    I am retired, don't have the $$$
  18. Jan 23, 2025 at 3:49 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Do you need a new front differential or a transfer case?
  19. Jan 23, 2025 at 5:18 PM
    Mr Badwrench
    Mr Badwrench New Member
    The answer is clear... "yes"
  20. Jan 23, 2025 at 5:24 PM
    Likely just needs the ECGS bushing installed
    ToyotaDude likes this.
