Can I add the front Aero Spoiler if not already equipped?
Discussion in '3rd Gen Tundras (2022+)' started by Papasparky, Apr 2, 2023.
  1. Apr 2, 2023 at 2:59 PM
    Papasparky
    Papasparky [OP] New Member
    Randy
    PORTLAND, OR
    2023 Tundra CrewMax Limited TRD-Off Road
    Running board and Tanneau cover
    MY 2023 Limited with Trd OR did not come with the front auto spoiler and I want to know if any has added it. I believe it will require the need to program it into the computer and find out how that gets done.
  2. Apr 2, 2023 at 5:45 PM
    JDSTOY
    JDSTOY New Member
    2024 GMC 2500HD, 2022 Limited 6.5, 2000 Limited
    Not to sound flippant, but why?
  3. Apr 2, 2023 at 6:49 PM
    ghunter321
    ghunter321 Trail Hunter
    NC
    2022 Blueprint Limited Tundra
    Retrax Pro XR bed cover, UpTop Overland mid truss system with Baja Designs rock lighting X6, GGOffroad rearview camera relocation kit, Pelican cargo BX90 case, Maxtrax recovery traction boards, OEM bed step, OEM dash and door trim/cubby/footwell lighting, Slee Offroad dual wireless Qi phone charger upgrade, CBI covert front bumper with air dam delete module, TRD Pro heritage grille replace with amber OEM marker lights, Diode Dynamics 18" white lightbar kit and OEM marker lighting, Diode Dynamics covert 18" amber lightbar, Rough Country bed mat, Rough Country defender series fender flares, TRD camo tailgate spoiler and OEM marker lights, TRD camo rear bumper arms, Screen Protech for interior surfaces, OEM badge blackout
    I have one if you need it. Happy to part with it under msrp. You should probably make sure you at least have the harness wired for it however first
  4. Apr 2, 2023 at 9:09 PM
    Papasparky
    Randy
    PORTLAND, OR
    As to why... I have seen multiple test performed that show a significant increase in highway mpg (3+ mpg) and I probably will never use this offroad anyway.
    Ghunter321, your right, before I jump and buy something, I want to know the ins and outs of doing it.
  5. Apr 2, 2023 at 9:16 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    I thought this thing retracted at 45+ mph...
  6. Apr 2, 2023 at 9:20 PM
    DexterL
    DexterL New Member
    21 lunar rock TRD pro Seqouia
    where? Mike sweers interview said it barely added any (like less than 5%)
  7. Apr 2, 2023 at 9:21 PM
    Papasparky
    Randy
    PORTLAND, OR
    Everything I've read states it will retract at 30mph and over
  8. Apr 2, 2023 at 9:25 PM
    Papasparky
    Randy
    PORTLAND, OR
    I'll have to look for where I saw the the videos and post here later
  9. Apr 3, 2023 at 4:39 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    I would be absolutely flabbergasted if that spoiler made .2 MPG while driving 70 MPH......
    The old 5.7/6-Speed is within 3 MPG of the new model. So all they had to do is put a spoiler/air dam in the old model and it would net the same mileage as the new model while still retaining the sought after v8 and reliability that comes with it?
    I would like to see what it takes to add one and how expensive it is just for the hell of it. I imagine all trucks are pre wired and there is a harness for it somewhere on the front of the truck.
  10. Apr 3, 2023 at 6:28 AM
    nodak67
    nodak67 New Member
    JR
    spoiler is only needed at an oem scale for cafe standards. gotta remember .1 or .2 mpg across 70-100k vehicles makes a difference for oem purposes only.
  11. Apr 6, 2023 at 2:02 PM
    Papasparky
    Randy
    PORTLAND, OR
    I am replying now because I searched out all through the internet where I thought. I saw the video on testing the to spoiler. I in fact could not find it for the Toyota. But there was a video on a Dodge where they had said to have gained 3 plus miles per gallon in a test that is absolutely of no value. I was looking for a long time for replacing my crushed Silverado crushed by a tree falling on it in December. I was looking at. Dodge or Toyota and. Toyota came out way on top , I found to many problems with Dodge. I finally decided that most everybody that commented was correct and coincides with all the data that I read about Tundra.
    Therefore, I thank everyone for your input.
  12. Apr 8, 2023 at 9:49 AM
    DMC11
    DMC11 New Member
    22 Tundra LR Limited OR
    Are you 100% positive your truck doesn’t have it? I didn’t think my 22 Limited w/ TRD OR had it as well. However, when I did my first oil change, I had to drop the spoiler(hold wash lever up, once you turn off truck) to access and remove the skid plate bolts.
  13. Apr 8, 2023 at 1:02 PM
    Dirtdog
    Dirtdog New Member
    2023 Tundra SR5 TRD off road premium
    Yes, I thought the Limited TRD OR did have the active air dam but the SR5 TRD OR did not.
    jeosbor1 likes this.
  14. Apr 8, 2023 at 3:05 PM
    Papasparky
    Randy
    PORTLAND, OR
    Positive it isn't there. I found that out when I was under the truck to install the CAT Sheild
  15. Apr 8, 2023 at 3:37 PM
    Will816
    Will816 New Member
    Will
    Idaho
    2022 Limited iForce Max TRD Off Road
    This is the only correct statement here. Regardless of what people claim, lip spoilers on trucks and SUV’s serve the manufacturers in CAFE standards, which are different than the EPA estimates you see in window stickers.
    Manufacturers will spend millions for those tenths of a MPG improvement. If you spend a couple hundred bucks getting one, it’s possible that you won’t recoup the cost over the duration of ownership.
  16. Apr 8, 2023 at 5:35 PM
    Dirtdog
    Dirtdog New Member
    The justification for the air dam is that it pushes the air that would otherwise be directly below the truck to the side to avoid the turbulence that you get on the bottom of the truck, due to the uneven surfaces. However, if you have the TRD skid and a CAT plate would an air dam make much of a difference? Probably not.
    Soupbean77 likes this.
  17. Apr 8, 2023 at 7:00 PM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    Why not just take one off an F150 and bolt it on. It wouldn’t be retractable but if you are off roading, you could just remove it. And bonus, no need to figure out the electrics!
    I was looking at a buddy’s Eco boost the other day and it bolts on.
    I didn’t get a spoiler as the CDN TRD Offroad option deletes the spoiler.
    I did install skid plates so maybe those will make up for the missing spoiler. ;)
  18. Apr 9, 2023 at 1:53 PM
    Will816
    Will816 New Member
    Will
    Idaho
    This is a good point. In the drag equation, velocity is squared so slowing down 10% results in almost a 20% reduction in drag
    Mattedfred[QUOTED] likes this.
  19. Apr 9, 2023 at 5:15 PM
    Papasparky
    Randy
    PORTLAND, OR
    All of these thoughts and remarks are convincing me to give up on the idea of adding that spoiler, it's becoming quite evident it's probably not worth the cost and effort to do so.
    Mattedfred likes this.
  20. Apr 9, 2023 at 5:52 PM
    Schneemann
    Schneemann New Member
    Would the fixed front spoiler from the ‘23 Sequoia bolt onto the Tundra?
