Can anyone identify this noise/tick?
Discussion in 'General Tundra Discussion' started by CaptainGrumpus, Jul 21, 2020.
  1. Jul 21, 2020 at 5:52 AM
    CaptainGrumpus
    CaptainGrumpus [OP] The Mailman
    Maine
    2018 Inferno Tundra TRD
    Random Ticking Noise From Passenger Side 2018 Tundra 5.7L
    https://youtu.be/1JE9JMZ_by8
    I posted this about a week ago but I took some better video and was hoping to get some ideas before I bring it in for service. The noise is random at idle but around 1500 rpms, it gets more pronounced. The truck runs strong and seems fine but this noise is driving me nuts.
    These are a few things I’ve done to the truck:
    AFE dry drop in filter
    Corsa cat back exhaust
    Recent oil change to Amsoil XL 0w20.
    Thanks in advance everyone!
  2. Jul 21, 2020 at 6:02 AM
    18" TRD Off Road Wheels
    Sounds similar to what my cummins used to do. Turned out to be the belt slapping because the clutch on the AC was going out. It'd jam up a little bit and the belt would bunch and skip making a ticking sound.
    CaptainGrumpus[OP] likes this.
  3. Jul 21, 2020 at 6:10 AM
    CaptainGrumpus
    Maine
    What about when your A/C was off? Is the condenser still doing something?
  4. Jul 21, 2020 at 6:14 AM
    Yup. Because it still had to turn as the belt went over it and the clutch was going it made the slap no matter what. If it's your belt slapping then it could be anything that the belt runs over. Can't definitively say it's the belt, and I am no mechanic, but that was the only thing I've experienced that sounded like that.
  5. Jul 21, 2020 at 6:24 AM
    CaptainGrumpus
    Maine
    Thanks for the info. I’m gonna take a look on at side of the bay. Maybe I’ll be able to narrow it down a bit.
  6. Jul 21, 2020 at 6:26 AM
    I just hope it was useful info! :rofl: Good luck!
  7. Jul 21, 2020 at 6:34 AM
    CaptainGrumpus
    Maine
    Anything is at this point :rofl:I hate going to the dealer.
    I just remembered that I had a dent PDR removed and the guy took the hood insulation pad thing off He dropped one of the clips into that part of the engine bay so maybe that what’s causing the noise. I just don’t see a piece of plastic would still be in the engine bay 3 weeks later rattling around at different rpms.
    GODZILLA[QUOTED] likes this.
  8. Jul 21, 2020 at 6:49 AM
    If it were more of a rattle than a tick I might have though it was the bolts on the side of the glove box. I saw a video somewhere and the owner found the bolts were loose and making a rattle. He had to pop the panel off the side that gets covered by the passenger door to get to them.
    Honestly, yours doesn't sound like a rattle to me, though.
  9. Jul 21, 2020 at 6:50 AM
    CaptainGrumpus
    Maine
    Yeah, I don’t think it’s a rattle either. I wonder if I should dump the Amsoil and put something else in.
  10. Jul 29, 2020 at 10:15 PM
    Any progress on your diagnosis?
  11. Jul 29, 2020 at 11:22 PM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    You said that you put on a corsa exhaust. Did you use new gaskets? There might be a slight exhaust leak at the flanges, maybe double check that they are all sealed and tight. Or maybe a loose heat shield.
  12. Jul 30, 2020 at 3:53 AM
    CaptainGrumpus
    Maine
    I just got in a mechanic stethoscope yesterday so I’m gonna do some investigating with that in the next day or 2. I did use new gaskets with the Corsa and retorqued after 500 miles. I will also check that again but the noise doesn’t seem to be coming from there.
  13. Jul 30, 2020 at 3:54 AM
    CaptainGrumpus
    Maine
    :frusty:
    Not yet. I had to delay my appointment at the dealer till the 2nd week of August because work has been crazy and I haven’t been able to get the truck there.
    I did disconnect my Sprint Booster and I switched to 93 octane and the noise did seem to quiet down a bit and it now happens a lot less often. I’m sitting in the parking lot at work now just idling and it’s not making the noise at all.
  14. Jul 30, 2020 at 4:27 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Curious: is your truck still under factory warranty?
  15. Jul 30, 2020 at 5:56 AM
    CaptainGrumpus
    Maine
    Yes it is. Not sure what month next year it expires though
  16. Jul 30, 2020 at 10:21 AM
    Malinois38
    Malinois38 New Member
    Pa.
    2022 Platinum Hybrid WCP
    Have you checked you cabin air filter? It’s in that area & worth a look. Could. Be some debris in there.
    GODZILLA and CaptainGrumpus[OP] like this.
  17. Jul 30, 2020 at 12:09 PM
    CaptainGrumpus
    Maine
    Good call! I didn’t even think of that!!
  18. Jul 30, 2020 at 3:55 PM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
  19. Jul 30, 2020 at 5:04 PM
