Can’t Unlock Door
Discussion in '2nd Gen Tundras (2007-2013)' started by james33440, Mar 19, 2021.
  1. Mar 19, 2021 at 4:47 PM
    james33440
    james33440 [OP] New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    I have a 2010 Tundra Double Cab. My rear doors and passenger door will not unlock with the key fob nor from the switch up front. However, they do unlock from each individual door except the rear driver side door.
    That specific door, the lock feels like the cable isn’t attached to it. I want to take the panel off and check the cable. However, I can’t open the door because it won’t unlock.
    Any ideas on how to unlock the door or get to the cable without being able to open the door?
  2. Dec 5, 2021 at 12:21 PM
    Bugsbunny
    Bugsbunny New Member
    2010 tundra
    I’m having the same issues with my2010 tundra. Did you find a solution to this issue?
  3. Dec 5, 2021 at 12:58 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    Pull the door panel and have a peek at the linkage.
  4. Dec 5, 2021 at 1:34 PM
    Bugsbunny
    2010 tundra
    Okay will try to look at it. Thanks
  5. Dec 5, 2021 at 4:15 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    When my son popped the cable out of one of my rear door locks, the electronic actuator was still sometimes able to unlock the door, though that wasn't super consistent since the cable wasn't attached and would get in the way.
  6. Dec 6, 2021 at 3:46 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    AAA? or someone who knows how to work a slim jim
