Camping Fridge/Freezer Setups
Discussion in 'Outdoors' started by Krezz, Mar 25, 2019.
  1. Mar 25, 2019 at 10:09 AM
    Krezz
    Krezz [OP] Doesn't want to be new member
    Kevin
    Southern Ontario, Canada
    2022 Tundra Crewmax Hybrid TRD Pro
    Who's running a fridge/freezer setup for their camping/overlanding/expedition style trips?
    Family of 4 here and we're more and more beginning to plan for 3 - 7 day long trips and I can see quickly wanting to move into a fridge/freezer setup and leaving the cooler behind.
    Looking for brands to research out.
    thanks!
    Mr. Moto likes this.
  2. Mar 25, 2019 at 10:15 AM
    4x4_Angel likes this.
  3. Mar 25, 2019 at 10:25 AM
    n2deep
    n2deep Pavement Princess
    Dometic or ARB are the best IMO. But decide where you want to install it because the tops open different and check dimensions. I use an 85qt Wyntner because it's the only one that fits in the spot I have for a fridge and the top opens the way I want it to. My compressor died on it in 2ys but replaced with a Danfoss about 2yrs ago and still running good.
  4. Mar 25, 2019 at 10:26 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    Running a Dometic CFX65W in my Four Wheel Camper. I love it.
    It holds plenty of food and snacks while not consuming a crazy amount of power. They have a CFX75DZW and CFX95DZW which are Dual Zone and feature a freezer compartment. This is nice for ice cream and other frozen items the kids might want
  5. Mar 25, 2019 at 10:29 AM
    Bailey
    CO
    FWIW
    Dometic makes the compressors for the ARB fridges. They are pretty much identical but the Dometic CFX series fridges see a slightly nicer unit.
    Black Wolf and Krezz[OP] like this.
  6. Mar 25, 2019 at 10:49 AM
    Krezz
    Kevin
    Thanks for the mentions so far! Going to check into these.
  7. Mar 25, 2019 at 10:58 AM
    n2deep
    I know ARB and Dometic use the Danfoss compressor - those are what you want as they use less power. The lids open differently so depending on what way you want it to open. I don't care for the ARB since the lids open long ways and not like a chest but it works for some that way depending on location
    831Tun likes this.
  8. Mar 25, 2019 at 11:12 AM
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    dometic cfx95 is what i grabbed. should be arriving while i’m on the road this week. bec will love that.
  9. Mar 26, 2019 at 9:55 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I recently scooped up a used ARB 63qt for $500, not sure what all you have done but having the fridge now means I get to upgrade to a group 31 battery also so keep that in mind also. Anyone have theirs mounted in the bed? Not sure I want to spend $300+ on a slide for it so looking for mounting options.
    myt1, Skey44 and aperezsh like this.
  10. Mar 26, 2019 at 10:18 PM
    Krezz
    Kevin
    Ended up getting an ARB Element, along with the slider and wiring loom.
    Going to mount into the bed and keep it removable when needed.
    545moose and Black Wolf like this.
  11. Apr 11, 2019 at 9:23 PM
    Levidale08
    Levidale08 New Member
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Homemade bed rack with extra spare with Rhino rack,two jerry cans mounted in the bed
    I have a Dometic fridge in the bed of the truck hooked up to a 150 watt solar panel mounted to the roof. And a 100amp hr battery mounted in the tool box. Works perfectly best investment ever.
    Mater, Mulligan1305, myt1 and 2 others like this.
  12. Apr 11, 2019 at 9:36 PM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
  13. Apr 29, 2019 at 6:01 PM
    kthomas
    kthomas New Member
    2004 tundra limited,trd
    Nice setup!
  14. Apr 29, 2019 at 6:26 PM
    Fishin RGV-Trd Pro
    Fishin RGV-Trd Pro White is faster
    Alex
    RGV Texas
    2011 White Toyota Tundra Limited
    Looking good. Don’t need to worry about ice.
    :thumbsup: :hattip:
  15. Aug 23, 2019 at 10:36 AM
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    I'm looking to add a dometic fridge/slider to the back of my rig. The fridge will only be used when we are camping, the truck is my daily driver. I have a switch pro with 2 open switches 35a and am wondering if I can wire this to the bed https://www.genesisoffroad.com/12vpoweroutlet-p/171-12v.htm
    20a fuse through the switch pro. then plug 7.9a fridge in?
    Less complicated explanation can I wire the 20a plug to the 35a switchpro to power the 7.5 a fridge with out blowing things up?
    Eventually I want to add a second battery but that will be some time before that happens.
  16. Aug 23, 2019 at 11:04 AM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    That would work but it would be better to run your own gage of wire. On my first set up used just the truck battery and ran the power to the bed. Cllena Dual USB Socket Charger 2.1A&2.1A + LED Voltmeter + 12V Power Outlet + ON-Off Toggle Switch Four Functions Panel for Car Boat Marine RV Truck Camper Vehicles GPS Mobiles (Green) https://www.amazon.com/dp/B072LN19K8/ref=cm_sw_r_cp_tai_ZNcyDbK0GHX7A
    SprinterAE86 and Grendel like this.
  17. Aug 23, 2019 at 11:08 AM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    I think I used 8 gage wire because you lose voltage the farther you go. You’ll like the usb to charge stuff in the bed. I’ve gone Lithium ion Battery for my fridge battery with the solar panel since then. The battery is much lighter and the fridge doesn’t take much off the battery
    Sunnier and Broncobroke like this.
  18. Aug 23, 2019 at 11:34 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
    Can you drive with the panel on the roof? How is it mounted?
    V2Arch and Luckydog like this.
  19. Aug 23, 2019 at 11:38 AM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Yes, 3m double sided mounting tape. Probably going to be a mo fo to get off.
    gladecreekwy likes this.
  20. Aug 23, 2019 at 1:10 PM
    Justin Case
    Justin Case New Member
    TX
    Brand of solar panel?
  21. Aug 23, 2019 at 2:19 PM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Renogy
  22. Aug 23, 2019 at 2:34 PM
    15whtrd
    15whtrd Mr. Blonde
    Challenger1 likes this.
  23. Aug 23, 2019 at 2:36 PM
    15whtrd
    15whtrd Mr. Blonde
    I’m jelly. That’s a really nice set up!
    Levidale08[QUOTED] likes this.
  24. Aug 29, 2019 at 9:27 AM
    Grendel
    Grendel New Member
    Thanks for the advice and link. What type of lithium battery did you use? Did you build a portable battery box or mount it on vehicle? Thanks for your advice.
  25. Aug 29, 2019 at 11:01 AM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Renogy Lithium Iron Phosphate Battery 12 Volt 170 Amp Hour https://www.amazon.com/dp/B07FDHRP45/ref=cm_sw_r_cp_api_i_9ibADbN0S7WEG
    I used a battery box from Academy cut the holes for the usb and 12 volt cigarette socket to plug the fridge in. And I mounted the battery box with self tap screws and it’s strapped down with d rings.
  26. Sep 7, 2019 at 1:38 PM
    fundra_goes_west
    fundra_goes_west I’m just a guy with a girl
    Evan
    2022 SQ8
    I will be doing a fridge freezer for next year as well. Nuthouse engineering makes a sweet slide I saw at the overland rally the year. Just need to add a portable water heater to it and it got everything.
  27. Oct 16, 2019 at 7:44 PM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I swear I’ve seen a dropping fridge slide that put it passed the tailgate before being able to lower it. Anyone know of one?
  28. Oct 25, 2019 at 7:07 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    FYI Costco has a 41qt. BLizzardBox on sale for 549.00 Usually 699.00
    https://www.costco.com/Blizzard-Box-12V110V-41-quart-Portable-Cooler.product.100505019.html
    Product Specifications:
    Capacity: 41 Quart (38.80L)
    Dimension:
    (Including Handles) 29.6” × 16.1” × 16.1”(38.80L)
    (752mm × 410mm x 410mm)
    USB charging port output: 5 V / 1.5A rating
    Climate class: 50ºF ~ 109ºF (10ºC ~ 43ºC)
    (SN/N/ST/T)
    Compressor: SECOP/Danfoss PBC-2.0
    Cooling Performance: 0ºF ~ 50ºF (-18ºC ~10ºC)
    Refrigerant: R134a (60g)
    Insulation: CFC-free PU foam
    Power consumption: 55W (as needed)
  29. Nov 18, 2019 at 10:27 PM
    crazydive
    crazydive New Member
    San Diego
    Hi,
    Does anyone has real experience with those? Because of Costco return policy I decided to buy it and so far I tested it at home. I'm not impressed. It is not showing the correct temperature and the compressor kicks in a lot. At ambient temperature around 75 it took 1 full day to freeze two small water bottles inside. When I turn it off temperature from 32 raises to 60 in matter of 1-1.5hr.
    Since I'm planing to build my fridge/battery/solar set I would like to know how much does it take energy when running on 12V in hot conditions (85F-100F) Most interesting for me would be total amp or Watt consumed in 24hrs. Sticker shows 4.2Amp at 12V what is actually 2x what ARB or Dometic is consuming, however this is just a general number describing max momentarily consumption.
  30. Nov 18, 2019 at 10:45 PM
    Challenger1
    Challenger1 Gramping
    Andy
    Southern California /Tustin
    I got the Arb element. Its weather proof and can be in mounted in the bed uncovered.
    Lots of great reviews. the stainless steel looks nice too.
    @osidepunker has an Arb 83qt he uses
    shellshock and osidepunker like this.
