Camper top seal kit??
Discussion in 'General Tundra Discussion' started by Ghostdriver, Feb 28, 2022.
  1. Feb 28, 2022 at 2:48 AM
    Ghostdriver
    Ghostdriver [OP] New Member
    Is there a company they sells affordable “seal kits” I’m picking up a new (used) shell and would like to seal up the rear cab window to the shell and also put something down on the bed rails. I know I can get foam or whatever but didn’t know if there was some sort of pre-cut well made seal to do the job.
  2. Feb 28, 2022 at 5:00 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Many do not use or need the rear window seal so it makes little sense to make a kit for both to me?
    I prefer the rubber twin bulb wide seal for the rails myself and the most expensive seem to be the best every time too. Rubber works better than foam and lasts longer too I think.
    I buy at body shop supply places and they are a whole lot cheaper than at retail too.
  3. Feb 28, 2022 at 9:14 AM
    Ghostdriver
    Awesome thanks, I’ll look into that! The rear window seal is because I was thinking of using the truck AC and a fan the help cool the bed in the summer…
