Camber bolts
Discussion in '2nd Gen Tundras (2007-2013)' started by Jason71, Jun 4, 2023.
  1. Jun 4, 2023 at 7:58 AM
    Jason71
    Jason71 [OP] New Member
    2011 tundra
    Lift big tires
    Replacing my lca s and guessing I will need new camber bolts. And experience with moog? Usually quality products
    Thanks
  2. Jun 7, 2023 at 10:24 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    OEM for life
  3. Jun 7, 2023 at 10:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Those bolts tighten at 207 lbs. get oem quality
  4. Jun 8, 2023 at 4:03 AM
    blackoutt
    blackoutt YEAH BUDDY!
    NWA
    07 DC Long Bed - Old Man Tan
    OEM+
    Another vote for OEM. The OEM alignment tabs are weak enough, don't need to introduce another rounding out failure point to the mix. Try to save what you can off the OEM hardware and reorder whatever you need to cut off. Hopefully you get lucky and it's only a couple parts or none!
    Jason71[OP] likes this.
