cam tower leak?
Discussion in '2.5 Gen Tundras (2014-2021)' started by hendricks, May 28, 2017.
  1. May 28, 2017 at 8:48 AM
    hendricks
    hendricks [OP] New Member
    hey guys I'm new to the page and the tundra world. i just bought my first the other day at a non toyota dealership. its a 14 cm 5.7 w/39k and when i got it home i noticed some oil recedew behind the passenger wheel, after further investigation i noticed more oil on the undercerriege. should i take this to a toyota tech and have it checked out first or take it strait back from where i got it and try and get my money back? N.Y. has a 5 day return on vehicles so i should be covered. here are some photos maybe someone can verify for me
    any help will do. Ill be really disappointed if this is the case because I've wanted a tundra for years and love this one other than this possible issue.
  2. May 28, 2017 at 9:03 AM
    I would get it covered. That isn't a cheap job. Vehicle should under the 5/60 warranty.
    Sucks man. I seen no oil on mine at 60k.
  3. May 28, 2017 at 9:06 AM
    hendricks
    i should be able to return the vehicle but have to wait out the long holiday weekend which will feel like etternity now. Its dissapointing that this may be my first tundra experience!
    NewImprovedRon and ColoradoTJ like this.
  4. May 28, 2017 at 9:11 AM
    It sucks man, but at least you caught it before hand.
    You can go either way. Have a Toyota dealership cover the cost of repair or turn it back into the dealership you purchased it from.
  5. May 28, 2017 at 9:19 AM
    I'd take it to a Toyota dealer since it should be covered under warranty.
    NewImprovedRon likes this.
  6. May 28, 2017 at 9:55 AM
  7. May 28, 2017 at 10:25 AM
    hendricks
    i know but i feel like if i can avoid the situation all together then i feel like thats probably the smarter thing to do.
  8. May 28, 2017 at 11:40 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    As @matluth stated I'd take it to Toy dealer mon/tues am and get it diagnosed. May not be under warranty.
    You'll then be armed with the information to make an informed decision.
    hendricks[OP] likes this.
  9. May 29, 2017 at 6:43 AM
    PMG
    PMG New Member
    It would also be in their system for such a problem and the next guy purchasing would see it documented in the event you pass on the car.
  10. May 29, 2017 at 8:53 AM
    hendricks
    i just recently thought of that, no sense of someone else getting stuck in my situation. first thing tomorrow morning I'm getting up to the toyota dealership!
  11. May 29, 2017 at 10:26 AM
    You're a good man.
    darkknight2014 likes this.
  12. May 29, 2017 at 7:09 PM
    hey_mikey
    hey_mikey New Member
    Concord, NC
    15 MGM Limited CrewMax 4x4
    Any updates? Returning the truck and getting another one doesn't guarantee that you won't run into the same problem down the road, so if it's covered under warranty and I was in your position, I'd push for a loaner or rental vehicle and get it fixed. If properly repaired, I doubt you'll see the same issue for the life of the truck.
  13. May 29, 2017 at 7:19 PM
    Just checked mine...2014 5.7 with 41976 miles it not as bad as your pic on pass left lil less buildup n its dry
  14. May 29, 2017 at 7:22 PM
    Bought mine used with 26000 miles gona take to dealer have it looked at
  15. May 29, 2017 at 7:28 PM
    hendricks
    dealers were closed today going to try and get in first thing tomorrow morning. any idea how often this is an issue? i looked through an older thread where it seemed there was a decent amount of guys that had this issue
  16. May 29, 2017 at 8:01 PM
    hendricks
    theres not a lot of buildup on mine, just in the one spot. however underneath the truck theres a good amount of somewhat fresh oil. makes me feel very uneasy
  17. May 29, 2017 at 8:30 PM
    Yeah id take back to dealer wher ya got from im gona do same when i get back
  18. Jun 1, 2017 at 10:23 AM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    How prominent is this issue with Tundras? Does it result in oil dripping onto the ground, or is there somewhere it pools which I should check periodically?
  19. Jun 1, 2017 at 10:47 AM
    hendricks
    just an update turns out no leak at all. previous owner sprayed some sort of oil based rust prevention all over the undercarriage and wheel wells and some of it got up where the cam cover and towers are. feeling relieved! thanks for all the help!
  20. Jun 1, 2017 at 12:12 PM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I read about the robot applying the sealant or maybe the sealant was bad, had this issue been resolved? I have a 2017 made in February and was wondering if this is something I should keep an eye on or is it "fixed".
  21. Jun 2, 2017 at 7:41 AM
    millerstone
    I'd like to know this too. I'm all paranoid that the first new car I ever bought will cost me more money down the road than my beater which leaked like a sieve.
    Hopefully Tundras aren't going the way of the third gen Tacos...
  22. Jun 2, 2017 at 8:42 AM
    hey_mikey
    Concord, NC
    From what I've seen from engine suppliers in the power lawn and garden world, if there's a misapplication of the sealant, the problem will make itself know fairly early on. I'd bet that any leaks related to this issue would become apparent before the warranty period ends so any repairs should be covered under warranty
    NewImprovedRon and millerstone like this.
