Caliraised behind the grille light bar brackets
Discussion in 'Lighting' started by CAM1794, Mar 24, 2019.
  1. Mar 24, 2019 at 8:19 PM
    CAM1794
    CAM1794 [OP] New Member
    Chad
    2017 MGM 1794
    I was looking into these brackets but looks like the air deflectors behind the grill have to be permanently removed. Will this have a negative effect on the truck or severe wind noise?
  2. Mar 24, 2019 at 9:20 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  3. Mar 24, 2019 at 9:35 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Just mod them like I did on my bro truck. I basically cut a slot to accommodate the bracket.
    LA184 likes this.
  4. Mar 24, 2019 at 9:46 PM
    Major
    Major TTC #0181
    Josh
    NC
    2017 CM Attitude Black Platinum
    Stock.
    I haven't noticed a difference with either.
  5. Mar 28, 2019 at 9:23 AM
    Caliraisedled
    Caliraisedled New Member Vendor
    Jake
    There should be any noticeable difference on it.
  6. Jul 4, 2020 at 6:38 AM
    VA10
    VA10 New Member
    2020 Tundra Limited TRD Off-Road
    Anyone been running the Caliraised light bar brackets? Especially in dirty/dusty/sandy environments? I just installed one 42'' curved light bar using the cali raised brackets. When the passenger side air deflector is removed it really opens up oil dipstick area. Does anyone have pictures of how they managed to modify the air deflectors to remain installed? I am leaning towards removing the brackets and using side mounts instead - this way I can keep the air deflectors installed.
    Cali Raised Brackets without air deflectors. They are well made brackets. Not sure its the best mounting option for a single light bar.
    VS.
    Standard light bar side mounts with air deflectors.
    After installing the 42” curved light bar using side mounts I switched back to the Cali raised brackets. The cross member is flimsier on my 2020 than it was on my 2015. I trimmed the stock air deflectors to fit with the brackets. No more open air flow to the oil dip stick or battery.
  7. Jul 7, 2020 at 10:13 AM
    VA10
    VA10 New Member
    Here are the brackets with trimmed air deflectors.
    LA184 and TheBeast like this.
  8. Dec 9, 2020 at 9:56 PM
    LA184
    LA184 Living the Dream
    2014 4x4, 4.6L Radiant Red Tundra
    4 in lift, 35s, Black Rhino Armory Wheels, Custom Rock Sliders, SDHQ ABS Guards, Warn Winch Bumper, Warn Evo VR 12-S Winch, 4.88 Re-Gear, Rear E-Locker.
    Any details on how you did this?
  9. Dec 10, 2020 at 5:10 AM
    VA10
    VA10 New Member
    @LA184,
    I trimmed the air deflectors using kitchen scissors. Using a set of metal snips would probably work best. I trimmed off pieces gradually as I test fitted the deflectors. The passenger side deflector is the trickiest - due to the hard lines and hoses in the way. Once you get the deflectors trimmed correctly they will fall into place and clip in very easily.
    matictundra likes this.
  10. Dec 10, 2020 at 7:55 AM
    LA184
    Thanks! Do you have the space to install 2 light bars or just one?
  11. Dec 10, 2020 at 9:24 AM
    VA10
    VA10 New Member
    You do have space to mount two bars - the light output from one of them might be terrible depending on the bar model /trim grill. You will probably have get creative with different bar models OR swap your grill out. The light output is terrible from the top and middle setting for my 2020 limited grill. On my 2015 SR5 (see above) the standard side mounts worked perfectly for one bar to shine through the lower large grill slit. On the 2015 SR5 grill I think two bars on the Caliraised LED bracket using the top and lower settings could have yielded good light throw from both the top and bottom setting.
    Based on your profile pic you will probably get the best performance from one bar.
    My setup
    • I mounted two 7'' round lights in between the top and middle settings - I drilled new holes. (output is usable and effective. mostly just looks cool....I would not do this again)
    • On the lower pre-drilled holes I mounted the curved 42'' light bar. (works extremely well)
  12. Dec 10, 2020 at 8:44 PM
    LA184
    Thank you for your response! It was very helpful.
    VA10[QUOTED] likes this.
  13. Dec 11, 2020 at 3:13 AM
    VA10
    VA10 New Member
    Glad I could help!
  14. Dec 11, 2020 at 7:28 AM
    matictundra
    Franco
    AZ
    I did the same but use my dremel with cutoff wheel.
  15. Dec 14, 2020 at 12:19 PM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
