Cali raised led switch install
Discussion in 'New Member Introductions' started by Knappb23, Sep 10, 2024.
  1. Sep 10, 2024 at 12:38 PM
    Knappb23
    Knappb23 [OP] New Member
    23 tundra sr5
    2" leveling kit, 35 12.50 r20 tires,,westin pro series front bumper
    I had a westin pro series front bumper installed with the fusion5 6" light bars. I want to install a cali raised switch for a more oem look. The light bar came with a toggle switch plugged into red and black wires, the cali switch has red, black green and white wires. I assumed red to red and black to black, didn't work. I got hold of cali and they said red to red black to black and green to relay. They said I would have to wire in a relay in order for the switch to work. I checked the wiring harness and it has a relay wired in. The black,and red wires on the toggle switch go into the relay. Any ideas on a wiring configuration or do I need a different switch?
  2. Sep 10, 2024 at 1:00 PM
    Savagesawyer
    Savagesawyer New Member
    Beaverton, OR
  3. Sep 10, 2024 at 1:16 PM
    Knappb23
    23 tundra sr5
    I'm not sure with only 2 wires coming from the relay harness, black and red. I spliced the white and black wires on the switch and connected them to the black wire from the harness and the led on the switch lit up when I turned it on, but no power to the lights
  4. Sep 10, 2024 at 7:53 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  5. Sep 10, 2024 at 7:59 PM
    Welcome from NY.
