cabin heater on 07 tundra 5.7L does not put out hot air. Anyone got an idea why and/or how to fix
Discussion in '2nd Gen Tundras (2007-2013)' started by bouncieboy12, Jan 11, 2018.
  1. Jan 11, 2018 at 9:27 PM
    bouncieboy12
    bouncieboy12 [OP] New Member
    cabin heater on 07 tundra 5.7L does not put out hot air. Any ideas on why or how to fix. Thanks.
  2. Jan 11, 2018 at 9:43 PM
    Are both of your lines hot going to the heater core? if they are, blend door actuator has taken a nose dive. Usually the default position, the air goes to the defrost location at your windshield. Can you get the HVAC system to go from the vents to the floor and back? that would eliminate the blend door.
    rons23 likes this.
  3. Jan 12, 2018 at 1:54 AM
    DalTee
    DalTee New Member
    Dal
    2011 SuperWhite CrewMax Limited
    Extang Folding Tonneau, 20 percent tint, TRD dual exhaust, BedMat, Stubby antennae, Bully Hitch Step, AVS Window Shades
    You check your in cabin air filter to see if it’s clogged
    Les7311 likes this.
