Cabin filter question??
Discussion in 'General Tundra Discussion' started by MER, Sep 23, 2020.
  1. Sep 23, 2020 at 9:30 PM
    MER
    MER [OP] New Member
    18' Limited CM 4x4 Off Road
    Just want to make sure I install my cabin filter the correct way...
    Bought a Fram Fresh Breeze cabin filter for my 2018 Tundra and the videos I’ve been watching says the air flow and arrow printed on the filter should point up... on my filter, the printed writing would be upside down if the arrow is pointed up.
    Should I install it this way?
    Or turn it upside down with the arrow pointing down?
    Thanks for the help.
  2. Sep 23, 2020 at 9:44 PM
    Kdogg77
    Kdogg77 If it ain't broke, it will be...
    Ken
    Central Cali
    2017 Tundra Crewmax
    6" RC suspension lift, 18" Pro Comp wheels, 35x12.5x18 tires, RC front/rear bumpers, RC Grill insert, Spider No Drill Roof Rack, Lighting by RC and Cali Raised. Interior mods include AJT Designs, Pioneer, and Rockford Fosgate.
    Arrow up. My words are upside down also.
  3. Sep 23, 2020 at 9:58 PM
    There are two types of filters out there. Some that say "This side up" with an arrow and then there are those that say "Airflow" and have an arrow indicating the direction air should pass through it. There has been lots of discussion elsewhere, but I believe the general consensus was that the air flows from top to bottom. If that is the case, your filter indicates that the arrow should point down.
    Beep88, Black Wolf, Mcoop and 3 others like this.
  4. Sep 23, 2020 at 10:27 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ I concur, air flow is down.
    Arrow should be pointing down.
    But the world won't end if it is pointing either way...:mad:
  5. Sep 24, 2020 at 4:52 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    The fan is below the filter, air is drawn down through the filter.
    SuperWhite20 and purplenova like this.
  6. Sep 24, 2020 at 5:10 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Now I gotta go pull mine out to see which way its installed - Thanks Guys...:confused:
  7. Sep 24, 2020 at 5:26 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    An easy way to tell direction of air flow is look at what side the debris is on the old filter when removing it... my 2019 was on the top meaning a downward air flow direction. :thumbsup:
  8. Sep 24, 2020 at 5:32 AM
    purplenova
    Tom
    Ohio
    glowblue likes this.
  9. Sep 24, 2020 at 5:47 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Airflow is down. That's why all the debris is on top of the filter. If it were the other way around, the debris would be behind the dashboard, in your glovebox, or the passengers side footwell. The Japanese wouldn't do that. That's something the Italians might do.
    ElNopal, BTBAKER, Baja Mike and 5 others like this.
  10. Sep 25, 2020 at 9:03 AM
    Stig
    Stig New Member
    Normally you have to lay upside down to install these
    Tundyfundy, GODZILLA and toyofan87 like this.
  11. Sep 26, 2020 at 7:20 AM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Air flow in our trucks is top to bottom as air come in from the top .so if it says air flow with an arrow on it,make sure the arrow is facing down.
  12. Sep 26, 2020 at 7:34 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    They make reusable filters should you decide to go that route in the future.
  13. Oct 1, 2020 at 10:08 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Cut it in half and place one arrow up and one arrow down. That way you’ll be right no matter which way the air flows. :devil:
  14. Oct 4, 2020 at 7:54 PM
    Zed
    Zed New Member
    Houston Texas
    2017 Brown 1794 Tundra
