Cabin Air filter
Discussion in '2nd Gen Tundras (2007-2013)' started by perl, Jul 2, 2021.
  1. Jul 2, 2021 at 11:34 AM
    perl
    perl [OP] New Member
    2011 White Tundra SR5 2WD 4.6
    I am confused about the air flow direction for the cabin air filter in the back of the glove box. Does the air flow from top to bottom or bottom to top? Thanks.
  2. Jul 2, 2021 at 11:35 AM
    Taco-Spike
    Two Trucks
    I think top to bottom?
  3. Jul 2, 2021 at 12:15 PM
    Blue Thunder
    Washington
    Fire up the truck and see
    07 Tundie likes this.
  4. Jul 2, 2021 at 12:17 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    The fan is below the filter and it pulls air down through the filter, so top to bottom is correct
    DeanoBambino64 and WILLINH like this.
  5. Jul 2, 2021 at 12:18 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    I think it's bottom to top. The blower motor is on the bottom under the filter and would blow air up to the vents.
  6. Jul 2, 2021 at 12:26 PM
    Taco-Spike
    Two Trucks
    https://youtu.be/tZivyeFN2Ag
    You can see at 1:33 in that debris is on the top coming from the cowl openings, airflow should be top to bottom. Blower is pulling air down
  7. Jul 2, 2021 at 12:41 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    The filters I have replaced have arrows that show air flow.
    Wallygator likes this.
  8. Jul 2, 2021 at 12:42 PM
    THinTX
    THinTX New Member
    Tony
    2018 MGM DC 4X4
    Top to bottom. Outside air is drawn in from the cowl.
    S0CKETMAN and NewImprovedRon like this.
  9. Jul 2, 2021 at 3:16 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    The problem with going by the arrows is that the factory filter's arrow shows which direction is up (filter orientation), while the replacement filters' arrow shows the direction of air flow, which are opposite, since air flow is from top to bottom. But in the grand scheme of things, it probably doesn't matter all that much how it's oriented, except to those CDO* folks like myself.
    *CDO - it's like OCD, but in alphabetical order, as it should be.
  10. Jul 3, 2021 at 3:32 AM
    Billy Bob Tundra
    Billy Bob Tundra New Member
    I change the cabin filter at least once a year and get them very cheap thru Rockauto.........but almost EVERY TIME I do replace the filter a dried up leaf or two will fall into the the squirrel fan and make a lot of noise if not removed. So I now use a small mirror to see inside the squirrel fan and pick out the dried up leaf before installing a new filter. Just a small tip for your future new cabin filter installation.
    Kn4x2, omgboost and WILLINH like this.
  11. Apr 24, 2023 at 5:43 PM
    DeanoBambino64
    DeanoBambino64 New Member
    Dean
    Saskatoon Area
    2008 Tundra Crewmax Limited 4X4 5.7L V8, 20"aluminium oem wheels.
  12. Apr 25, 2023 at 7:19 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Buying OEM definitely takes the guess work out of it for me. My OCD self spent way too much time overthinking things when I went aftermarket, I couldn’t tell which was the right way. OEM has an arrow and says up…worth the extra $ for me at least.
  13. Apr 26, 2023 at 11:52 AM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    clear as mud fellas thanks for getting that figured out.
    grave likes this.
  14. Apr 26, 2023 at 12:01 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    the air flows from top to bottom.
    Like this,...
    And the fan always sucks air through the filter, never trying to push the air through the filter. Just like any air filtration unit, forced air furnace, etc.
    So if the fan is below the filter, it's sucking air down, through the filter.
    Reference the pic above for flow direction.
    dundunDUN, S0CKETMAN and omgboost like this.
  15. Apr 26, 2023 at 1:18 PM
    shannon
    shannon New Member
    shannon
    Asheville, NC
    2010 DC
    Love it!!!
    RichterScale[QUOTED] likes this.
  16. Apr 26, 2023 at 1:22 PM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    I always wanted to be the guy that writes the directions on stuff.
    I think I got what it takes.
    Dalandshark likes this.
  17. Aug 11, 2024 at 12:28 PM
    JackDerwint
    JackDerwint New Member
    2010 Limited 4x4
    I think I can clear up some confusion if anyone is still stuck on this…the cover that seals the filter in has an arrow ^ and says up on it, which makes sense as the tabs that hold it in place are not centered top to bottom(so it’s telling us which end of it is up and has nothing to do with the filter placement). The outer cover for the cover that seals the filter(the back of the glove box ‘not-so-secret’ hiding place cover has not one but two arrows pointing up and says “slide up and remove”…yet again these arrows have nothing to do with the fact that the air flows through the ductwork from top to bottom so any “air flow” directional arrow on an aftermarket filter(probably a bit cheaper that the OEM that likely has arrows on all four edges pointing in alternating directions that say “up”, “the other way”, “over there”, and the last one is simply ‘the finger’ (the one that feeds regurgitated worms to its little fingers), pointing up naturally, and says ‘you White, I Wong’. I have to believe that there are many automobile engineering meetings of the minds where there is lots of laughter going on as they come up with new ways to confuse people into paying too much for routine maintenance with proprietary misinformation(for example the valve that has to be held open with a paper clip before starting the Simon says routing to drain and properly replace the ATF on these trucks, I watched 12 videos and only one guy in Australia pointed out the valve, all others were shocked that only 3 quarts drain out), they also have similar meetings at Ford when they’re rolling dice to see where to put hidden metric fasteners and designing proprietary tools! Hope this makes someone laugh…
    joonbug likes this.
  18. Aug 11, 2024 at 12:37 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Air flows toward the footwell
  19. Aug 11, 2024 at 2:25 PM
    Rathesun
    Rathesun New Member
    Alaska
    2013 Tundra Double-cab 5.7L engine
    It is as simple as this:
    a. If the filter has an arrow only, the arrow points up. This is NOT telling you that the arrow show "airflow", just the filter's top surface. This usually is the case with dual layer filters, or a filter that has a layer of "activated charcoal" and the rest is just paper. The layer of charcoal should be on top, not at the bottom because the fan would blow charcoal dust into the cabin.
    b. Airflow in most automobiles takes place with the intake near the top, not under the automobile. The fan always pulls air into the cab, not the other way around. The fresh air being pulled into the cab goes downward through the air filter and then the fan blades pushes it into the air vents.
    c. If you buy a new filter and the words, "AIRFLOW" are stamped on it, plus an arrow pointing down, then install it with the arrow pointing down, because it has nothing to do with which layer of the filter being the top or the bottom, just with the airflow.
    https://www.youtube.com/watch?v=tZivyeFN2Ag
  20. Aug 13, 2024 at 12:07 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    i believe it is side-to-side
    Dalandshark and S0CKETMAN like this.
  21. Aug 26, 2024 at 8:04 PM
    S0CKETMAN
    S0CKETMAN New Member
    07 Limited 4x4 CM Slate Metallic
    Psssst.......its always top to bottom. ;)
  22. Nov 30, 2024 at 2:48 PM
    dkurtz42
    dkurtz42 New Member
    David
    Wanted to verify airflow was down. After taking the filter out…ya, I guess it’s down lol.
    pvn.beluga likes this.
  23. Nov 30, 2024 at 3:07 PM
    Wallygator
    WILLINH likes this.
  24. Dec 1, 2024 at 8:55 AM
    Cruiserpilot
    Cruiserpilot New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Geez, glad none of you guys are design engineers for Space-X. :rofl:
  25. Dec 5, 2024 at 10:17 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Just shove it in. You got a 50/50 chance of getting it right.
    Wallygator, Half Assed and JMGmanAZ like this.
  26. Dec 5, 2024 at 10:30 AM
    PKFan
    TWSS
  27. Dec 5, 2024 at 10:48 AM
    SD Surfer
    Bruce
    So Cal
    If my experience with USB cables is any indication, that 50/50 chance will be wrong 100% of the time.
  28. Dec 5, 2024 at 2:02 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Holy shite. You too??????????
  29. Dec 5, 2024 at 2:59 PM
    SD Surfer
    Bruce
    So Cal
    Yep, sometimes I even stop and think to myself...
    "They're ALWAYS upside down, so I'm gonna' flip it over first."
    mtndude23 likes this.
  30. Dec 6, 2024 at 4:33 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    As per manual instructions found in glove box.
