Cabin air filter flow direction
Discussion in 'General Tundra Discussion' started by joonbug, Jul 1, 2018.
  1. Jul 1, 2018 at 2:59 PM
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Replacing my cabin air filter. Original has “this side up”. New one only has air flow direction. Anyone know which way the air flows? Up or down?
    geno0506 and 831Tun like this.
  2. Jul 1, 2018 at 3:02 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Never mind. Pretty sure air flow is down. The up side on the stock filter had all the dirt.
  3. Jul 1, 2018 at 3:04 PM
    There's no arrows indicating which way?
  4. Jul 1, 2018 at 3:11 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    The filter has arrows. Wasn’t sure which way the air flow was on the truck.
    coldcanuk and 831Tun like this.
  5. Jul 1, 2018 at 3:21 PM
    Arrows go up
  6. Jul 1, 2018 at 3:24 PM
  7. Jul 1, 2018 at 3:26 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    My filter doesn’t have an “up”. It only has an air flow direction. Which was down.
  8. Jul 1, 2018 at 3:26 PM
    :confused:
  9. Jul 1, 2018 at 3:33 PM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Lol. If the air filter has arrows that say “this side up”, then the arrows should point up. But if the filter has arrows indicating the air flow direction, then the arrows have to point down. Looks like the air flows downward because my old filter had all the dirt on the top side of the filter.
  10. Jul 1, 2018 at 4:44 PM
    Hello????? The outer plastic cover that you remove indicates air flow direction....insert filter accordingly...just sayin...and I've had two CO high octane craft brewskies....
    831Tun and TXRailRoadBandit73 like this.
  11. Jul 1, 2018 at 7:27 PM
    tundras00
    tundras00 New Member
    Not necessarily. I ran into the same thing when replacing to an ACDelco filter. It got me for a sec though, although I'm in the HVAC trade.
  12. Jul 1, 2018 at 7:31 PM
    The arrow on the filter goes in the same direction as indicated on the cabin filter housing cover.
    SOB likes this.
  13. Jul 1, 2018 at 7:36 PM
    tundras00
    Nobody got time for that.... Was done hastily, and only noticed when trying to put it back on.
  14. Jul 1, 2018 at 7:40 PM
    Actually the same happened to me the first time I swapped a new one in. :thumbsup:
    tundras00[QUOTED] likes this.
  15. Jul 1, 2018 at 8:19 PM
    tundras00
    We are men after all. :)
  16. Jul 1, 2018 at 8:21 PM
    tundras00
    Do shit first, read directions ONLY if we run into problems.
  17. Jul 1, 2018 at 9:06 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    That's what I figured too. Air flows is down.
  18. Jul 1, 2018 at 9:09 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    It’s probably gonna work fine either way
    Dougr6 and Black Wolf like this.
  19. Jul 1, 2018 at 9:11 PM
    Yep...main thing for me is for it to catch leaves, etc....
  20. Jul 1, 2018 at 9:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Seems, after an exhaustive internet search (2 min. tops), it's a fairly common question. I think the OEM filter points up as does the outer plastic cover. However, I think, and read, the airflow is actually top to bottom which is consistent with the accumulated dust and debris. So, no OEM filters that indicate air flow direction are installed with air flowing down orientation. Wow, that was exhausting, I need a vacation. :notsure:
    15whtrd and joonbug[OP] like this.
  21. Jul 1, 2018 at 9:19 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    You should get paid double for all the work you put in!
  22. Jul 1, 2018 at 9:22 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That would amount to............ well,,,, wouldn't buy a cup of coffee.
    joonbug[OP] likes this.
  23. Jul 1, 2018 at 9:35 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Damn you making me wonder if I put mine in the right direction!
    This is when I did mine. Have photos of your filter?
    joonbug[OP], geno0506 and 831Tun like this.
  24. Jul 1, 2018 at 9:46 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yours looks right to me. Yours says up^^^^^ this way. Mine says airflow.
    joonbug[OP] and geno0506 like this.
  25. Jul 1, 2018 at 9:51 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The one that says up is the old filter. The black one is the new one.
  26. Jul 1, 2018 at 10:02 PM
    My line of thought is irregardless of air flow, I position the filter with the"arrow" the same direction as the cover.
    831Tun[QUOTED] likes this.
  27. Jul 1, 2018 at 10:49 PM
    geno0506
    geno0506 New Member
    Michael
  28. Jul 2, 2018 at 7:30 AM
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
  29. Jul 2, 2018 at 7:52 AM
    I know...a stupid filter.......
  30. Jul 2, 2018 at 3:05 PM
    geno0506
    geno0506 New Member
    Michael
    exactly and thats why I get jacked up every time I go to change it!
