C1300 and C1336. VSC OFF (flashing), Traction, ABS, Brake. Caused by welding.
Discussion in '2nd Gen Tundras (2007-2013)' started by WhiteTundra08, Dec 11, 2023.
  1. Dec 11, 2023 at 8:50 AM
    WhiteTundra08
    WhiteTundra08 [OP] New Member
    2008 Tundra 5.7L 4x4 Double Cab
    2008 Tundra 5.7L 4x4 Double Cab. Immediately following welding on exhaust without disconnecting the battery or ECU, dash lights are now on - VSC OFF (flashing), Traction, ABS, and Brake. Codes are C1300 and C1336. Snap-On Apollo D-9 unable to clear codes. Other than that, truck is running fine. Any advice?
    I see a Diag.Net post with the same situation but as a non-mechanic cannot access the website. If anyone has an account, please share a screen shot of the thread. Maybe the answer is there. https://diag.net/msg/m6rdb0487fbyklthf55vl96kzk
  2. Dec 11, 2023 at 8:55 AM
    The C1336 is for a zero point calibration fail for the yaw control system. Need a recalibration which I believe is done with a scanner / computer via OBD.
