C Rated Tires?
Discussion in 'Wheels & Tires' started by travpayne, Jul 2, 2019.
  1. Jul 2, 2019 at 10:31 PM
    travpayne
    travpayne [OP] New Member
    17 Tundra CrewMax 4x4
    Hello all,
    Im looking for some insight on tire selection. Ive had BFG AT on a few trucks in the past, and I really like them. They are quiet, aggressive enough, and wear well IMO. I live in northern California, and don't spend to much time off road, I don't tow more then a jet-ski, and rarely have heavy loads. I do spend a good amount of time in Tahoe though.
    anyway,
    I am trying to figure out if running a "C" rated tire will be adequate enough?
    it saves about 7lbs per tire compared to the "E" rated tire.
    I am also getting the 17x8.5 Method (MR309) wheels to go with the tires.
    Tire Size - 285/70/17
    Any thoughts or suggestions would be greatly appreciated!!
    Thanks!!
  2. Jul 12, 2019 at 3:49 PM
    Chucho
    Chucho New Member
    Rob
    Salem, OR
    2017 MGM DC Tundra SR5 TRD 4X4
    Tuff Country 2" Level spacer Kit up front Paired with KYB Mono Max shocks all around. Roadmaster Active Suspension HD kit 1mm gap 275/70R18 Falken Wildpeak A/T3W mounted on some MB352 18X9 + 25 Cobra 19DXIV CB radio.
    You should be fine with "C" rated tires. The Tundras come stock with "P" rated not even an "LT".
    Back in the day all 1/2 ton SUV & Trucks came with "C" rated tires.
    I might look into these on my next set.
  3. Jul 12, 2019 at 3:59 PM
    15whtrd
    15whtrd Mr. Blonde
    I know everyone wants an E rated tire nowadays but P rated is still adequate for what the truck can tow and carry. You should be fine with the C rated tire.
    ColoradoTJ likes this.
  4. Jul 12, 2019 at 5:59 PM
    ricsha
    ricsha One is none, two is one.
    Rich
    Oregon Coast
    2019 Tundra Limited TRD
    Just my thought and worth what you pay for it; but, why have a truck and put car/suv tires on it? 100% pavement, a P rated tire or a C rated tire is probably fine. Spend even a little time at all off road, or on gravel roads, and I'd go with LT tires. More weight, yes; but, more plys so more able to withstand rock punctures, and if you do want to haul occasionally you can do it without worry. Heavy duty tires = piece of mind.
  5. Sep 8, 2019 at 8:36 AM
    travpayne
    Thanks for the information.
    I’ve decided on the BFG 285/75/17 KO2
    They may hurt they bank a bit, but I know they will last!
  6. Sep 8, 2019 at 8:39 AM
    Grumpy Uncle
    Pat
    CO
    Ran DuraTrac Cs on my Tacoma. I had no concerns with them.
  7. Sep 8, 2019 at 8:42 AM
    travpayne
    I’m just a little concerned with the amount of sidewall with the larger tire / smaller wheel “swimming” around on the road.
  8. Sep 8, 2019 at 8:50 AM
    Grumpy Uncle
    Pat
    CO
    Mine were 285/75/16s, never felt squirrelly. I know the Tundra is heavier, so I cant say how they will perform.
    The C rated tires stayed on my Tacoma for about 35K miles. Even when I gave the truck to my oldest boy.
  9. Sep 8, 2019 at 9:49 AM
    travpayne
    Oh ok. Thanks for the information! I’ve already committed I think..
    But I will keep them in mind for next time!
