C/OPN Relay not Operating
Discussion in '2nd Gen Tundras (2007-2013)' started by Lumpycorn, Jun 5, 2020.
  1. Jun 5, 2020 at 1:25 PM
    Lumpycorn
    Lumpycorn [OP] New Member
    Hi All,
    The C/OPN relay is not closing. The control for this relay comes from the ECU. Are there any ECU input conditions that would prevent the computer from closing the relay? I'd like to check those before buying an ECU.
    Thanks in advance!
  2. Jun 6, 2020 at 9:33 PM
    stomachbuzz
    stomachbuzz New Member
    if you're going to jump at buying a replacement ECU that fast, it might be worth the time to test the relay itself first lol
  3. Jul 19, 2022 at 10:15 PM
    GDON1976
    GDON1976 New Member
    Where is the C\OPN relay located?
  4. Jul 20, 2022 at 7:40 AM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Engine Fuse box #6 according to this. It is the Circuit opening relay that powers the fuel pump
