bypass kits
Discussion in '2nd Gen Tundras (2007-2013)' started by tmac58star, May 3, 2025 at 10:59 AM.
  1. May 3, 2025 at 10:59 AM
    tmac58star
    tmac58star [OP] New Member
    Black 1st generation Tundra SR5 Access Cab
    I know of the Hewitt kit, but what others are there for an '07 SR5 Tundra with 4.7L V8?...links?
    Thanks in advance.
  2. May 3, 2025 at 11:25 AM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    There is also https://rutechsolutions.com/collections/all
    They really work well with 07 and 08 years. It's hit and miss with later years as most have updated their ecu's to cycle the air pumps at various times.
    You could also buy block off plates and DIY AIP override to change the temp at startup so it doesn't cycle. I've been running the DIY for quite awhile.
