Buzzing noise after recharging dead battery
Discussion in '1st Gen Tundras (2000-2006)' started by flewis99, Jul 15, 2023.
  1. Jul 15, 2023 at 7:31 AM
    flewis99
    flewis99 [OP] New Member
    fred
    2006 Tundra Crew SR5
    While replacing a leaking wheel cylinder on my 06 Tundra my battery went dead. I began to charge the battery and immediately a buzzing noise coming from the passenger side wheel well(?), that I assume has something to do with the ABS(?) So, I disconnected the battery cables to prevent any damage, then continued the charge.
    When I reconnected the cables, the buzzing continues. So I wait one day, then two days and reconnect the cables again, still buzzing. I disconnect again.
    We did bleed the brake at this wheel and kept reservoir full. Could this buzzing be getting fluids recirculating or could it just be a bad part?
    Any suggestions or advice is greatly appreciated.
  2. Jul 15, 2023 at 8:08 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    Have you put pressure on the brakes while its buzzing?
  3. Jul 15, 2023 at 9:02 AM
    flewis99
    fred
    No sir. Trying to do this alone, so didn't think I had time to do anything but disconnect the system before any damage. If you are suggesting that may stop or help with the buzzing, I'll definitely give it a try.
    Thank You
  4. Jul 15, 2023 at 9:06 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I dont have a clue. If you get it to buzz again, feel the abs unit & see if you feel vibrations?
  5. Jul 15, 2023 at 9:53 AM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Is the noise from the rear wheel well area, or front? If rear, I’m thinking it’s the pump running for the EVAP leakage test.
