Buzz vibration in gas pedal.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dennisryan19, Mar 15, 2018.
  1. Mar 15, 2018 at 6:34 PM
    Dennisryan19
    Dennisryan19 [OP] New Member
    2018 limited
    I have 600 miles on my new 2018 limited tundra CM. Have a slight buzz vibration in the gas pedal. Happens on a light acceleration. Saw some other posts on this. Anyone else have this issue??? Weird. Some out there say it’s just normal?? Thanks!!!!
  2. Mar 15, 2018 at 7:49 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Sure it's not your abs
  3. Mar 16, 2018 at 5:36 AM
    Berettafan
    Berettafan New Member
    2017 CM
    I don't think Toyota does a good job isolating vibes from the motor in these trucks. In spite of what many say I feel the 5.7 is a coarse engine and you'll feel that from time to time.
  4. Mar 16, 2018 at 6:42 AM
    Dennisryan19
    2018 limited
    Thanks. I have also heard to give it some break in time and they go away. Net ranger 6. ABS should not give a buzz if there are no issues correct??
  5. Mar 16, 2018 at 10:31 AM
    71_340
    71_340 The German
    Hans
    FLW, MO
    Mine doesn't vibrate and I really can't see how it would since it is fly-by-wire and there is no physical connection (cable) from the pedal to the throttle body. Did you check if the mounting screws are loose? If not take it to the dealer and see what they have to say. At any rate, if you spend around 50K you should be completely satisfied.
  6. Mar 16, 2018 at 10:33 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I feel vibration at low rpm....thought it might just be my TRD exhaust. I only drove Kevin for about week before installing the exhaust so not sure if the vibration was there with stock.
  7. Mar 16, 2018 at 11:12 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    normal. I feel mine from acceleration to stop. i'ts not a bad vibration, just feels like regular engine vibration.
  8. Mar 16, 2018 at 4:13 PM
    Dennisryan19
    2018 limited
    Thanks for the feedback everyone. Actually over the past week this has slowly dissipated. Drove all day today with little or no buzz/vibration. Break in time maybe? All else is good. Love the truck!! Former f150 owner to a Tundra! Now time to figure out how I keep this black leather interior staying clean!!
  9. Jan 18, 2019 at 10:08 PM
    NoOneEveryone
    NoOneEveryone New Member
    2016 Tundra SR5
    Glad to see that I'm not the only one. Just picked up a 2016 with ~50k miles and I feel a slight buzz in the gas pedal at certain RPM. I think the gas pedal just amplifies it because I feel it in my left foot through the floor as well.
    In my experience vibration at certain RPM is resonance and that's usually coming from the exhaust, but can be anything out of balance - flywheel for example.
    Annoying but not a big deal if nothing is shaking loose.
