Buying First Tundra 08
Discussion in '2nd Gen Tundras (2007-2013)' started by EAADK, Apr 22, 2021.
  1. Apr 22, 2021 at 6:17 PM
    EAADK
    EAADK [OP] New Member
    Very interested in a 2008 TRD Double Cab 4x4 with about 103k. Any big service items in the history that should've been done or things to look out for, anticipate in the future on this 4.7 V8? Will be piling up some highway miles towing a small pop up trailer and doing some light off road use.
    Dealer said the frame was replaced by Toyota, the water pump was replaced in 2015, this is low miles for the year, carfax looks decent, miles legit no accidents, serviced pretty regularly. This would be my first real truck so appreciate any help, thank you!
    • Model2008 Tundra
    • GradeSR5
    • ExteriorSlate Metallic(1F9)
    • InteriorBlack
    • Engine8-CYL
    • Body TypeDouble Cab
    • Drive Type4WD
    • Transmission5AT
    • Servicing DealerNone Selected
    • Date of First UseJuly 31, 2008
    • ADDITIONAL VEHICLE DETAILS
    Order Date:
    04/2008
    Plant of Manufacture:
    Body Style:
    DBL CAB 4.7L SR5
    Tire Make/Brand:
    Tire Size:
    Spare Tire Brand:
    PORT OR FACTORY INSTALLED EQUIPMENT
    • 2Q All Weather Mats
    • Port
    • FE 50 State Emissions
    • Factory
    • HM Heated Mirror
    • Factory
    • OF TRD Offroad Package
    • Factory
    • SP SR5 Package
    • Factory
    • STANDARD INSTALLATION EQUIPMENT
    • Exterior
      6.5' Double-Walled Bed w/Tailgate Assist Black Handles, Pwr Htd Outside Mirrors Chrome Grille Surround, Fr & Rr Bumpers
      Safety
    • STAR Safety: Pwr Assist 4 Wheel Disc ABS w/Electronic Brakeforce Distrib (EBD), Brake Assist, Vehicle Stability Control with Active Traction Control (VSC+ATRAC) Dr & Fr Pass Advanced Airbags/Seat Side Airbags/3 pt Seatbelts w/Pretensioners & Force Limiters Roll-Sensing Curtain Airbags (RSCA) Tire Pressure Monitoring System
    • Mechanical & Performance
      GVWR = 6900 lbs. Payload = 1435 lbs. 276HP/313 Lb-Ft 4.7L DOHC 32V V8 w/VVT-i 5-Spd Automatic Trans w/Sequential Shift Engine Immobilizer, Cruise Control 4WDemand 4x4 System w/Electronically Controlled 2 Speed Transfer Case Tow Equip/Capacity (Except when equipped w/Sport Appear Pkg): Tow Cap = 7800 lbs. Hitch Receiver, Supp A/T Cooler, 4.10 Rear Diff w/9.5" Ring Gear, 130A Alternator, A/T Temp Gauge, 7 Pin Conn, Trailer Brake Controller Prewire Automatic Limited Slip Diff (Auto LSD) TripleTech Frame: Fully-boxed Fr Section Reinforced C Under Cab, Open C Under Bed Coil Over Shock Double A-Arm Front Susp Multi-Leaf Trapezoidal Rear Suspension w/Staggered Outboard Mounted Shocks 18" Styled Steel Wheels P255/70R18 Tires Pwr 4 Wheel Disc Brakes, 13.9" Fr Rotors
    • Interior
      Cloth Buckets w/8-way Pwr Adj Drvr-side Tilt/Telescoping Steering Wheel Dual Zone Climate Control w/Sync Mode AM/FM/6-CD w/6 Speakers & Aux Audio Jack Center Console w/Laptop & File Storage Power Windows/Door Locks/Mirrors Remote Keyless Entry System
  2. Apr 22, 2021 at 6:27 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Welcome from LA (Lower Alabama)! Looks like a great find! Not bad mileage for a 13 year old truck!
  3. Apr 22, 2021 at 6:52 PM
    Dr Doobie
    Dr Doobie Growing member
    Talkeetna,Alaska
    '07 RCSB 5.7 SC'd 4x4 SSM
    Welcome from Alaska
  4. Apr 22, 2021 at 6:57 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    When the water pump was done, was that also the timing belt? That would tend to big the big item with the 4.7.
    Trident and Voss like this.
  5. Apr 23, 2021 at 5:15 AM
    fixnfly
    fixnfly New Member
    08 double cab 5.7
    Check for bed rust.
  6. Apr 23, 2021 at 7:51 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    At that mileage and age:
    replace timing belt- super important! if it breaks it can destroy the engine. There are other maintenance items replaced during this service too.
    spark plugs
    drain and fill all fluids, grease all zerks
    crawl up under it and look for any rust, check bushings, suspension
