Buying a high mileage 1st gen
Discussion in '1st Gen Tundras (2000-2006)' started by bxnanaz, Dec 18, 2020.
  1. Dec 18, 2020 at 5:37 AM
    bxnanaz
    bxnanaz [OP] New Member
    I’m looking at possibly buying a 300k mile 2005 crew cab 4x4. It’s an SR5, very clean frame and interior with a pretty minor dent in the passenger door area. 2 owners, appears to be maintained very well. He’s asking right at 5k. What are y’alls thoughts?
  2. Dec 18, 2020 at 5:42 AM
    GIN•OKUMA
    GIN•OKUMA Can’t get to SSEM from there. RGBA1
    Fish
    26.57°
    Noun; a machine, usually with wheels and an engine, used for transporting people or goods, especially on land
    When was the timing done last?
  3. Dec 18, 2020 at 5:43 AM
    bxnanaz
    supposedly 30k miles ago. Rear bearings, seals, and fluid was just done
  4. Dec 18, 2020 at 5:44 AM
    jpink
    jpink Aspiring Shade Tree Mechanic
    Knoxville
    05 Black Tundra DC SR5
    Pics? Pics of underneath?
    Tundra2 likes this.
  5. Dec 18, 2020 at 5:51 AM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    If the seller can't produce documentation showing when the belt was done, do yourself a favor and verify that it was in fact done like he said. On the right side (passenger side) of the engine, remove a couple of 10mm bolts from the plastic cover that conceals the Timing Belt. You'll be able to see just how new that belt really is when you pull that cover away from the engine... a TB with 30K on it should still look almost new, not shiny and certainly not showing any cracks.
  6. Dec 18, 2020 at 5:52 AM
    bxnanaz
    BDF41729-CB55-4824-892A-D3CC672EF8A3.jpg E3F2B7B2-0946-4309-B635-27F2B3EEB9F7.jpg
    Filthyphil likes this.
  7. Dec 18, 2020 at 5:53 AM
    The 300k is pretty high obviously. The motors are strong and can go forever, but some of the fiddly bits age, rot and fail just like every car. Anything made of rubber, anything underhood made of plastic. $5k isn't a bad entry price if it's fully functional. If it was meticulously maintained, maybe most of these things have been inspected and replaced as needed and you're not too far behind. Pics of frame underneath and general condition would be helpful. Depending on where this car spent it's life, rust could be a major issue. Even more helpful is take a mechanic friend, or take it to a trusted mechanic for a once over before purchasing. Good luck sir
  8. Dec 18, 2020 at 5:56 AM
    bxnanaz
    There are a lot more pics than that. Interior is tan cloth, clean. I am very mechanically inclined and will check over stuff with a fine tooth, but wanted to ask owners thoughts on that price, and overall buying a high mileage 1st gen.
  9. Dec 18, 2020 at 5:59 AM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    As long as it’s been maintained, that’s not a high mileage truck for these vehicles. That’s middle aged lol
    jpink, Schcoman, Glock 40 and 3 others like this.
  10. Dec 18, 2020 at 5:59 AM
    Good news, based on the imaging of the underneath, I would say that's a clean frame and rear diff cover sir. Further inspection is always warranted, but these are either rust buckets, or they are not. This one appears not. The shot of the valve train assembly with the cover off is a little concerning. What type of oil and what interval was he changing it? Must have been dino oil? I've run synthetic at 10k intervals the last 150k miles and the inside of my valve assembly was pristine shiny silver, just like it left the factory. None of that brown varnish tint. May not matter, there's no sludge buildup that I can see. Nice looking truck.
    bxnanaz[OP] likes this.
  11. Dec 18, 2020 at 6:02 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    That ain't no up north truck, I tells ya...
    300K is a lot, but we're not talking about an F-150 or a Silverado here... It appears that the truck was very well maintained, so it's not out of the realm of possibility that it's as good as it looks..:thumbsup:
  12. Dec 18, 2020 at 6:18 AM
    jpod
    jpod its Finally here
    London Canada
    2020 Tundra CM Cement Grey
    Diamondback HD, 1Up Racks, Yakima Bars, Garbage Weston Steps
    300k? It's almost broken in then.
    jpink, Darkness, Schcoman and 3 others like this.
  13. Dec 18, 2020 at 6:42 AM
    delz05
    delz05 Old relic... Living and Loving Life!!!
    BOSTON
    2005 Tundra Limited
    Work in progress...
    2500.. for the one I last purchased... 267k at the time, new frame, but I had to do all the required maintenance... previous owner did the bare minimum... I would gladly have spent the extra money on purchase in order to have saved the parts and lablor...
    Who am I kidding... I would have found something that needed fixing...!!!
    Check that rear axel housing and the backing plates... very labor intensive if any needs there...
    N84434 likes this.
  14. Dec 18, 2020 at 7:20 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Prices will vary depending on your location, but I think it's at the TOP of asking.
    A LIMITED, then, sure.
    bxnanaz[QUOTED][OP] likes this.
  15. Dec 18, 2020 at 7:32 AM
    A cursory check of prices within 500 miles of my location:
    No DC Tundras available for $5k. Cheapest is a 2006 with 255k miles for $6k. And it looks beat.
  16. Dec 18, 2020 at 7:44 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    300k isn't a problem. Asking price is very fair, it's a 15 year old truck so be prepared to do some maintenance on it and in return it will last a long time and will be reliable.
    If it is to your liking, buy it.
    Sunnier, bxnanaz[OP] and Glock 40 like this.
  17. Dec 18, 2020 at 7:51 AM
    Just make sure its not a rust bucket. No amount of money saved on the purchase price will soften the blow when you go to replace anything on the truck. Clean frame and non-rusty components are worth the extra dough up front. Well maintained is a plus. Oh, and check the 4wd. Another person just purchased one earlier this year and tried to use it for the first time in a snow storm and it didn't work.
    N84434 likes this.
  18. Dec 18, 2020 at 8:32 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    My 87 4Runner had 285k when I sold it before I had to deploy overseas.. Thing ran like a tank... If you like it, buy it or look for another... So many out there. Timing is everything.
  19. Dec 18, 2020 at 8:37 AM
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Fixed.....
    toyofan87[QUOTED] likes this.
  20. Dec 18, 2020 at 8:39 AM
    daveyjames207
    daveyjames207 New Member
    Dave
    2013 SR5 DC 4x4 5.7 Off Road Nautical Blue Metallic
    That doesn’t look bad at all. Most likely below the rust belt. The 300k isn’t too concerning, however since you said you’re mechanically inclined, check over seals and gaskets and plastic parts for rot. I may try to talk them down a bit, but honestly if everything checks out that isn’t bad.
    Filthyphil and Darkness like this.
  21. Dec 18, 2020 at 9:14 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    I love listening to my dumbass yuppie brother gasping at trucks with 90 thousand miles on them like that's a lot. Meanwhile us over here dont even flinch at 250k. Damn idiot BMW owner
  22. Dec 18, 2020 at 9:28 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    For a German car 100k is time to sell usually. Those cars start nickel and diving you to death, even if you do the work yourself like I do, the parts are expensive for German cars. He should sell that thing and buy a Lexus and stop worrying about mileage.
    Toyota, and particularly these trucks, don't have much that goes wrong other than rust.
  23. Dec 18, 2020 at 9:30 AM
    Pucks18
    He wants to sell it. He drives a 2013 (I believe?) 355i or 325i coupe. One of those two, pretty sure 355i. It's a 4 cylinder. He only has 39k on it but hes looking for trucks but he likes the fords. He just needs to buy a tundra and be done with it!
    Darkness[QUOTED] likes this.
  24. Dec 18, 2020 at 9:39 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    He should sell it while he can still get good money for it and buy a used Toyota. Ford wouldn't be my first choice even if I wasn't a Toyota guy.
    Pucks18[QUOTED] likes this.
  25. Dec 18, 2020 at 11:11 AM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    5k would be a steal on that thing in CA if its as clean as it appears in those pics. You being mechanically inclined is just a plus to fix any needed wear items as they show up.
  26. Dec 18, 2020 at 1:35 PM
    Professional Hand Model
    Hand Protectors
    Use a flash light and crawl up under the truck. Look specifically at frame portions just behind front wheels and just in front of rear wheels. Need pics from laying directly under the truck looking out and not pics from standing/squatting outside looking in/under.
    Sunnier, N84434 and Pucks18 like this.
  27. Dec 18, 2020 at 3:38 PM
    PenderBen
    PenderBen Forum lurker…
    Gulf Islands, BC Canada
    2003 Tundra AC 4x4
    A bit OT, but we’ve had BMW’s for decades and never bad experiences, on the other hand I’m not sure about the newer ones, we never moved past e46 because they’ve been so solid and reliable for us. One of my dad’s e36’s (his ‘93 325i) we sold early 2000’s with 225k on it, nothing but standard maintenance it’s whole life, even had the original clutch.
    I have found Toyota and BMW parts on par price wise.
    That being said, I fully support the statement that Toyota/Lexus are solid, long lived low maintenance vehicles, and the Tundra is a solid truck, that’s why we’ve all got them, right? :)
    Back on topic; OP, where is it located? It’s a bit hard to see the potential problem areas in those pics, and there’s definitely rust on back, what appears to be the hitch frame.
    PHM’s advice is right on, get under it with a light and prod at any rust you see, if there’s anything bubbling or flaky, work at it, maybe even take a flat screwdriver with you to prod with. Depending on where it’s located, from what I see it looks promising, and a decent price.
  28. Dec 18, 2020 at 4:39 PM
    bxnanaz
    I’m in SC. No rust at all. Truck drives good! All seems in order.
    Stuck in the '00s and Sunnier like this.
  29. Dec 18, 2020 at 4:46 PM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE TRD OR; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads Husky liners
    i got a rust free Californian, all toyota dealership maintenance per manual then some for 3500 with 290k.
    I am not due for belt and pump til 370k
    knock him down
  30. Dec 18, 2020 at 5:32 PM
    Sunnier
    Sunny
    San Diego, CA
    I agree you should get under the truck to photograph any rust you want us to evaluate. Jab the rusty surfaces with a screwdriver. If it’s solid, maybe try and talk the seller down, but have the asking price near at hand. If it’s not rusted and you don’t buy it quick, someone else will.
