Buy Warranty on 2011 Toyota Tundra
Discussion in '2nd Gen Tundras (2007-2013)' started by shanemorton, May 13, 2019.
  1. May 13, 2019 at 3:11 PM
    shanemorton
    shanemorton [OP] New Member
    2011 Pyrite Mica V8 5.7L Grade
    None at the moment.
    I have a question, recently bought a used 2011 Toyota Tundra 5.7L with 120,000 miles on it for $13,000 (Do not know if pricing is allowed). Is it even possible to get a extended warranty for it that a good deal? As far as I know, there ain't any major wrong with it yet, but I do have fear sometime in the future could happen. Which warranty plan should I get since the truck is older than the new ones.
    Thanks
  2. May 13, 2019 at 7:55 PM
    Yodder J
    Yodder J New Member
    Northwest Arkansas
    2011 Silver Tundra SR5 4WD DC
    DAP Tune, Truxedo ProX15 bed cover, WildPeak AT3s
    I would research the truck's history (carfax) and then maybe see what the dealer options are. If you are buying it from a dealer, they are going to try and sell you a warranty of some kind.
  3. May 13, 2019 at 7:57 PM
    markg
    markg New Member
    Mark
    NC
    2007 TRD
    If you're in the North where they use a lot of salt and slag for winter, I would check the frame.
    Soccer4strom likes this.
  4. May 13, 2019 at 8:21 PM
    kcaustin66
    kcaustin66 New Member
    kevin
    Palestine Texas (East Texas)
    2015 Toyota Tundra CM 1794 4wd
    3” lift, black step bars, aftermarket wheels, LT305/55R20 was this way when I brought it.
    On son in law purchased a 2010 Tundra with 125000 miles he purchased a extended warranty from - Route 66 warranty. He has had very good luck with it
  5. May 15, 2019 at 7:11 PM
    shanemorton
    None at the moment.
    The problem is, bought the truck from Toyota Goldsboro, NC. I do not want to deal with them again if possible because they didnt do anything I ask nicely before I picked up the truck that Sunday. It's a long story really. They threw away the backup camera that they had cut off, didn't check the tire sensors because the light was on, turns out someone removed them from the tires. It goes on...
  6. May 15, 2019 at 8:21 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Guessing you really wanted this truck. When things are going poorly at a dealership, its time to walk.
    Research any EW, many have deductibles that can be high. Not big on EW's myself, would rather self warranty, put that money in the bank
    Good Luck!
  7. May 18, 2019 at 12:19 PM
    Soccer4strom
    Soccer4strom New Member
    Rich
    2012 White Tundra TRD Crew max
    wash the undercarriage, grind off the rust on the welds and nuts, spray the undercarriage.
  8. Feb 20, 2020 at 12:54 AM
    ogieruiz
    ogieruiz New Member
    Augustine
    2008 tundra
    I purchased an extended warrenty from Vanguard vehicle armor and when I went to use it I was told they would only cover fourty percent of repairs, be careful alot of them are rip offs.
  9. Feb 20, 2020 at 1:16 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    As Trooper2 said, 'warranty' it yourself. I mean come on its a toyota not a fiat-chrysler or ford. Invest the money instead....
  10. Feb 20, 2020 at 2:24 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    How handy are you? Can you do somethings yourself. With 120,000 miles there will be things that need routine maintenance. Shocks may need replacing, fluids, etc. Some of these things may not be covered under an extended warranty.
  11. Feb 20, 2020 at 4:19 AM
    B.Ross
    B.Ross New Member
    Southern Utah
    2012 TForce CrewMax 4wd
    That mileage wouldn't concern me. I would, as routine maintenance/ new to me vehicle replace all the fluid ( oil change, trans flush, fr/ r diffs and trans case (if 4wd)) as well as spark plugs. Cheap insurance really. My 2¢.
