Button
Discussion in '2nd Gen Tundras (2007-2013)' started by TWTundra, Sep 25, 2019.
  1. Sep 25, 2019 at 8:45 AM
    TWTundra
    TWTundra [OP] New Member
    2012 Tundra 4.6
    There is what appears to be a button (it pushes in when pressed) that is next to the headlight leveler switch (shown in picture). What exactly does is is for?Button.jpg
  2. Sep 25, 2019 at 8:45 AM
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Aftermarket alarm. Used as an LED/programming button combo
  3. Sep 25, 2019 at 8:48 AM
    TWTundra
    2012 Tundra 4.6
    Ah... so then it should light up when engine is off and doors are locked?
  4. Sep 25, 2019 at 8:48 AM
    Dmas
    Dmas New Member
    FTL, FL
    2018 SR5 Tundra DC TRD Off Road 4x4
    most likely and aftermarket alarm system like the previous post said.
  5. Sep 25, 2019 at 8:49 AM
    ZeRussian
    ‘11 CrewMax
    Depends if it’s active. Typically starts doing a very slow blink when doors are locked and the alarm is armed to let anyone know that you have an alarm. I’ve seen Toyota factory keyless/alarm modules that are not factory installed look like this too
  6. Sep 25, 2019 at 8:51 AM
    ZeRussian
    ‘11 CrewMax
    If you are very curious, you can always follow the thin wire attached to the button which would lead you to the “brain” you’ll be able to tell the model by looking at the markings on the brain.
    JohnLakeman likes this.
  7. Sep 25, 2019 at 8:55 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Someone has to post it :rofl:
  8. Sep 25, 2019 at 8:56 AM
    TWTundra
    2012 Tundra 4.6
    Ok... great... thanks everyone for the quick responses!
  9. Sep 25, 2019 at 5:33 PM
    Fozzy360
    Fozzy360 New Member
    Hunter
    2010 Tundra Crewmax Limited
    Stock
    Damn beat me to it
    TXMiamiFan[QUOTED] likes this.
