Burn out
Discussion in '3rd Gen Tundras (2022+)' started by malveman, Aug 21, 2023.
  1. Aug 21, 2023 at 5:15 PM
    malveman
    malveman [OP] New Member
    New jersey
    2022 Limited long bed MGM
    Hi guys I have a 22 limited non Trd the window sticker said limited slip rear so why is it that when I stomp on the gas the tire I’m assuming one spins until I get off the gas my other tundra’s didn’t do this thanks in advance for any help
  2. Aug 21, 2023 at 5:45 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Do you mean - when you floor it, only one rear wheel spins instead of both rear wheels?
  3. Aug 21, 2023 at 5:50 PM
    malveman
    New jersey
    No that would b posi traction I thought limited slip would stop or slow down the wheel so u would get better traction
  4. Aug 21, 2023 at 6:15 PM
    Hella Krusty
    Hella Krusty New Member
    What exactley are you asking? 1 tire spins its limited slip...posi is both. Go out and lay some rubber and answer you own question
    Tundra family and Blufin like this.
  5. Aug 21, 2023 at 6:17 PM
    pronstar
    pronstar New Member
    Robert
    Not a Tundra :-(
    2015 Silverado: 2.5” Kings front/rear. Icon Delta Joint UCA’s. Deavers. 17” Method 703 BeadGrips. 33” BFF KM3 2018 Suburban: 2.0” Fox front/rear. Dirt King UCA’s. Mall Cruiser.
    One-wheel peel with posi = broken posi
    GNTundra and 4genRunner like this.
  6. Aug 21, 2023 at 6:21 PM
    malveman
    New jersey
    Sorry I mis understood the last Tex. I am wondering why any wheel would spin when u get on it I thought limited slip would control the wheel that’s spinning aggressively and slow it down for better traction
  7. Aug 21, 2023 at 6:31 PM
    pronstar
    pronstar New Member
    Robert
    Not a Tundra :-(
    That’s how it’s supposed to work, but there are other factors to account for like how much/little traction is available to each wheel.
  8. Aug 21, 2023 at 6:36 PM
    malveman
    New jersey
    Ok thanks I just don’t Remember the 5.7 engine spinning the tires so easily
  9. Aug 21, 2023 at 6:46 PM
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    That’s right bby, these snails got some huevos!!
  10. Aug 21, 2023 at 6:56 PM
    Breathing Borla
    Northern Illinois
    lol, welcome to 479 at 2,400, ha!
  11. Aug 21, 2023 at 6:58 PM
    Breathing Borla
    Northern Illinois
    Welcome to more and lower torque club. :burnrubber:
  12. Aug 21, 2023 at 7:43 PM
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Ya, that low end tq pulls my enclosure great. Always felt like I was hard on the truck when towing in my 2019 .
  13. Aug 22, 2023 at 1:03 AM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    Positraction IS a limited-slip differential. Positraction was simply a General Motors brand name.
    You should be able to get both tires to spin with a limited slip differential. With a locker, Lincoln locker (welded differential), or a spool you WILL spin both.
  14. Aug 22, 2023 at 3:28 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    ^^^This would be traction control^^^
    Limited Slip means both rear wheels will pull (spin) if you get on the throttle. A great way to see this is comparing the two in the rain. I used to have a non-limited slip in a Silverado years ago and it would not go anywhere if you had to pull out in the rain on a hill, one tire would spin easily when giving it the gas. So I ordered a limited slip differential and installed it. If one wheels starts to spin, it will lock the differential so that both wheels now get traction instead of only one. It gets much better traction with limited slip. If you do a burn out, like your title said, without limited slip, it leave one black line...with limited slip, it leaves two.
    k0diak8o8 likes this.
  15. Aug 22, 2023 at 6:34 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    This may have been said but I think it helps to compare all three systems for clarity
    Auto Limited Slip used brakes (traction control) to slow the spinning wheel that does not have good traction. This is the Tundra Auto Limited Slip. Both tires might spin together if there is low traction and lots of power.
    Posi or Limited Slip differential uses clutch packs in the differential to send a more even amount of power to each wheel but does not fully lock the two wheels together. They may spin together on slippery surfaces or when doing a burn out but that is different from locking. This system is good because you can make turns and the clutch packs will slip enough to let the truck turn and not buck. I wish Tundra came with this option because it works awesome on rain and snow covered roads without needing 4x4.
    Locking differential does what it says. It locks the two wheels together. Years ago the Detroit Locker was a favorite but it bucked and made tight turns difficult. Very popular in drag racing and serious off roading. This is similar to the Tundra electric locking differential that comes with the TRD OR Pkg and can only be used in 4Lo
    Hope this helps clear up the three types of differentials.
    Jettster and Ginsterkev like this.
  16. Aug 22, 2023 at 7:15 AM
    Hella Krusty
    Which does exactly what I posted
  17. Aug 22, 2023 at 8:35 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
    No. Posi(traction) and limited slip will behave exactly the same. Posi(traction) is simply a GM brand name for limited slip.
    You said that they would behave differently. You said “1 tire spins its limited slip...posi is both.”
  18. Aug 22, 2023 at 8:47 AM
    OP, your truck does not have an LSD rear end. No 2022's do to my knowledge. You may have Auto-LSD, which as previously described is not an LSD at all, but part of the traction control system. It will use the brakes to help control wheel spin, but can certainly be overpowered by stabbing the gas. You may also have the optional locker with the TRD Offroad package. Neither of these is active unless you specifically activate them. The locker is only available in 4Lo as I understand it and the Auto-LSD has to be activated by pushing the button on the dash. If you just hopped in and put it in drive and stabbed the gas, one wheel peel it is.
    Retired...finally, RickC and des2mtn like this.
  19. Aug 22, 2023 at 8:53 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Hey you stompers, y'all getting second-gear scratches like in 1970..:thumbsup:
  20. Aug 22, 2023 at 8:54 AM
    Breathing Borla
    Northern Illinois
    I haven't tried to light em up yet, I like my new coopers to much lol.
    I will say, when you put it in sport +, I have no doubt it would torch them if you wanted to, its goat a ton of low end torque at low RPM
    1lowlife[QUOTED] likes this.
  21. Aug 22, 2023 at 9:05 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Is that like your old tow/haul button?
  22. Aug 22, 2023 at 10:03 AM
    Hella Krusty
    LOL...OKAY
  23. Aug 22, 2023 at 10:29 AM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  24. Aug 22, 2023 at 10:35 AM
    CNE0207
    CNE0207 New Member
    Arvada, CO
    2020 Cement CM Limited
  25. Aug 22, 2023 at 10:39 AM
    One of the best accidently-stumble-across-on-TV-while-flipping-channels movies of all time. Can't change the channel. Classic.
    1lowlife likes this.
  26. Aug 22, 2023 at 11:13 AM
    fyrfytr26
    Eastern PA
    2021 DC SR
  27. Aug 22, 2023 at 11:16 AM
    War Machine
    War Machine SSEM # 5 3MW
    I know I don’t have it on my ‘64 Buick Skylark.
    CNE0207 likes this.
  28. Aug 22, 2023 at 11:21 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Could you be more specific?:confused::cool:
  29. Aug 22, 2023 at 2:04 PM
    malveman
    New jersey
    Wow thanks for all the feed back much appreciated
  30. Aug 22, 2023 at 3:17 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
