Bumpstop extensions needed or not?
Discussion in 'Suspension' started by scpete24, Aug 15, 2018.
  1. Aug 15, 2018 at 12:13 PM
    scpete24
    scpete24 [OP] Duuuuuuude
    Orange County, CA
    2016 TRD Pro Super White
    I have the pro suspension and have (2) shims on each side for 1" more of lift. My question for you guys is do you think I need bumpstop extensions with this set-up or not?
    Thanks for any responses!
  2. Aug 15, 2018 at 1:20 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    My Bilstein 6112s came with two large diameter washers (one for each side) that appear to be about 1/8” thick, presumably to add to the stock bump stops. I set mine at the 1.9” ride height and added the washers to the rear most bump stops as a bit of extra insurance. Not sure if the washers were intended for those who set theirs at 2.5” or at any of the ride height options, though.
    Does your TRD Pro have washers in between the bump stops? If not, it may be that Toyota decided they weren’t needed for an additional 2” of front ride height.
  3. Aug 15, 2018 at 1:25 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    From what I'm told by credible sources, the bump spacers Bilstein provides is to prevent coil bind issues, not so much shock related. FWIW
    equin likes this.
  4. Aug 15, 2018 at 1:27 PM
    15whtrd
    15whtrd Mr. Blonde
    No they don’t come with extensions on the bump stops. But he added an extra inch of ride height on top of the 2” Pro suspension so he’s wondering if he’s going to be bottoming the shocks out before the bumps hit. I’ve read that our pro suspension has integral bump stops. But I don’t truly know the answer.
  5. Aug 15, 2018 at 3:03 PM
    scpete24
    Orange County, CA
    You are correct with what I am asking. Hopefully someone with more knowledge and similar setup can chime in
    15whtrd[QUOTED] likes this.
  6. Feb 21, 2020 at 3:20 PM
    NateDiz
    NateDiz Sunday Tunday
    Nathan
    So Cal
    2013 MGM CrewMax TRD
    Trd Pro Suspension, spyder headlights with morimoto HID, Raceline Defender Wheels, AFE filter, Dirty Deeds 8” exhaust
    I could use the answer to this question. Im rocking TRD pro suspension on my 2013 and am tempted to put shims up front because i have them lying around. I am probably just going to order the extensions to be safe.
  7. Feb 23, 2020 at 2:43 PM
    rustytoys
    rustytoys New Member
    I would like to know too; but on a basic level wouldn't you just measure the gap on your current bump stop and make sure that measurement is less than the measurement of your available to compress shock shaft?
  8. Dec 5, 2020 at 9:49 PM
    Krewcial
    Krewcial So good with my rod, I make fish come!
    Don
    2010 DC (3UR-FE) & 2000 AC (2UZ-FE)
    -Kings 2.5’s shocks -JBA UCA -Wheelers front bumpstops -Torque air bags with Daystar air bag cradles -Alcans leaf’s +700 lbs 1” lift -Dobinson grease-able shackles -TRD front and rear sway bars -RCI Engine, Transmission/Transfer Case skid plate -RCI Catalytic Guard -RCI sliders -Magnum ICI RT series bumpers -Auxbeam 72W Amber 4" round spot off road lights -Morimoto XB LED headlights -Level 8 MK6 +12 offset 18" rims wrapped with 285/75/18R Falken AT3’s with TRD centercaps -TRD dual exhaust with black chrome tips -AFE Power Magnum FLOW Pro DRY S Air Filter -TRD air accelerator -WeatherTech floor mats -Aftermarket Sequoia Grill -MAX Modular bed rack with tonneau brackets -Diamondback HD tonneau -James Baroud Grand Raid XXL -OVS 270 awning -11” Alpine iLX-F511 media receiver
    Bump... Hopefully @Coachbuilder1 can help answer this question. My thoughts are if you add a .5” shim up front for 1” of additional lift on the trd pro shocks you should have CB bump stop extensions on the front rear bump stop? And maybe a 1/8” washer or two on the front front bump stop? I know CB pro kit has the .5” shims and 4 bump stop extensions in it.
  9. Dec 5, 2020 at 9:54 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The shims limit your potential up travel. I would rather chuck the shims, but if not definitely run bumpstop spacers to make sure the shock doesn’t bottom out before your suspension.
    LKTundra likes this.
  10. Dec 15, 2020 at 1:30 PM
    LKTundra
    LKTundra New Member
    Les
    2016 Tundra
    Sus- Lots of Icon Lights- Baja Designs/ KC Shoes- RW's on BORA/ 35in General X3's Protection- RCI/ WhiteKnuckle/ Jomax Brakes- EBC/ Motul/ SDHQ
    Measure your bumpstop gaps forward and rearward(different heights) before the shims and after shim install move the bumpstops down the gap needs to be the same. If you use to large of a bump spacer you'll be on them more often and the ride will suck
  11. Sep 10, 2022 at 5:16 PM
    _steezysr5
    _steezysr5 New Member
    Instagram _steezyse Eibach pro lift stage 1 3.5/1.5 Rough country shims/block Methods nv305 double black 18x9 +25 Bfg ko2 35 12.5 Alpharex pro series headlights/taillights Lasfit ls plus series led Armordillo Hood Grille Insert with Led Lights Bakflip mx4 tri fold tonneau cover 5 inch iboard running board Pedal commander RCI Transmission and catalytic converter shield Nameplate overlays 5% tint all around Titan wheel spacer 1 inch Weather mats by 3dmatsusa Rydonair 7 inch Gplus third brake light Paint-matched hood bulge, grille surround, front and rear bumper overlays from Ecoological (midnight black metallic) Mbrp dual rear exit exhaust (mimics trd exhaust sound) yet to install, currently just a muffler delete
    I have the RWD tundra planning on installing an rc 3inch leveling kit. I bought the complete kit since I didn't know that its only for the 4wd. my question is do I only install the leveling spacer or do I need to install the bump stop extensions as well? I know I don't have a dif in front so I won't be needing the dif drop spacer.
  12. Sep 11, 2022 at 6:18 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Bumpstops define the upper limit of suspension travel. A spacer lift changes the shocks ability to compress/extend in that suspension arc. Point your arm straight out and lift your arm up and down. This is how the a arms move as well. With a spacer lift, your shock will be fully compressed before your arm hits the factory bumpstop, thus the spacer
    snivilous likes this.
  13. Sep 11, 2022 at 6:20 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yes buy a 1" spacer for your bump stops. @Coachbuilder1 has them.
  14. Sep 11, 2022 at 7:28 AM
    _steezysr5
    Appreciate the replies. I already have the spacers as I mentioned I have the complete leveling kit. Will be installing leveling spacer and bump stop spacer only. Videos on YouTube doesn’t show adding a bump stop spacer even on a 4x4 unless it’s an actual lift kit. Which created the confusion for me if actually needed to install bump stop spacer along the leveling spacer. New tundra owner here I’m learning a lot fast in just the pass month since I got the truck thanks for y’all contribution.
