Bump stops??
Discussion in 'Suspension' started by se3388, Feb 28, 2025.
  1. Feb 28, 2025 at 5:08 PM
    se3388
    se3388 [OP] New Member
    2025 Tundra I Force Max Platinum Crew Cab, 1997 Toyota T100 SR5 Ext. Cab 4x4, 2014 Tacoma Dbl Cab Short Bed 4x4 TRD Sport
    OK, I am installing a 2 inch strut spacer to level out my 2025 Tundra Platinum 4x4. I received my spacers and am wondering about the bump stops. I searched the 3 Gen forum about bump stops and couldn't find out what size bump stop or what size spacer I would need, I may have overlooked it.
    With the 2 inch strut spacer is it better to go with longer bump stops (assuming they are available) or spacers? Where would they be available? Thanks for any info.
    Steve...........
  2. Mar 1, 2025 at 2:33 PM
    osu1978
    osu1978 New Member
    Westcott sends a 1/4" bump stop spacer with their 1/2" shim (~1" of lift) for reference.
    BDS uses a 1/4" bump stop spacer with their 2" level kit. Not sure on the actual thickness of their strut shim though but it should be in the 1"-1.25" range.
  3. Mar 1, 2025 at 6:55 PM
    se3388
    Thanks for the info, my 2-2.5 inch strut spacers actual measurement is 1 3/8 inch so in my inexperienced opinion I think I might need 1/2 inch bump stop extension spacer. Hopefully that will work.
    Guess it's a little late to ask but is it bad for the front suspension to do a strut lift even if it is only 2 inches? I have seen a few comments about increased wear on the lower ball joints. Mine is just a daily driver with the occasional field road or forest road with minimal mud.
    Steve..........
  4. Mar 3, 2025 at 12:13 PM
    osu1978
    osu1978 New Member
    I think its fine for street and light off-road and you are doing the right thing by extending the bump stop. I would not go with any more lift up front though.
