Bullydog tundra programmer
Discussion in 'Performance and Tuning' started by Tundrapwr16, Oct 10, 2021.
  1. Oct 10, 2021 at 10:27 AM
    Tundrapwr16
    Tundrapwr16 [OP] Best Toyota made ever
    Rob
    California
    2000 RC 3.4 liter white work truck .
    Pioneer radio and intermittent wiper switch and led lights. I also use AMZOIL Products only..
    Does anyone run the Bullydog programmer in there truck?. Just wondering what are the best settings to use? And how do I get the gas pedal less sensitive to the touch??. Thanks..
  2. Oct 10, 2021 at 1:26 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Set it up like this:
    tune premium
    Throttle trail
    Shifting performance
    Speed unlimited
    TX210Tundra and Saltyhero13 like this.
  3. Oct 10, 2021 at 1:40 PM
    Tundrapwr16
    Rob
    California
    Ok will do. Another question? Im running 295/70/18s. Does this bully dog adjust speedo for the tire size I’m running?? Also any thing for better fuel mileage? Truck sucks on fuel mileage..
    dirtydeeds likes this.
  4. Oct 10, 2021 at 1:50 PM
    dirtydeeds
    Keith
    USA
    The tires can’t be adjusted for. That’s a different ecu on our trucks. All you can do is regear it. That would make it shift right and give you a little better fuel economy. The tuner settings would make it drive a lot better.
  5. Oct 10, 2021 at 2:07 PM
    Tundrapwr16
    Rob
    California
    Ok cool. I just need to do updates. Got it from a friend it’s like new. I didn’t like the touchy throttle very scary to me. So the settings you gave me will put it almost to stock throttle feel.?
  6. Oct 12, 2021 at 9:43 PM
    dirtydeeds
    Keith
    USA
    Given your problem, the settings listed above will provide the solution.
  7. Oct 12, 2021 at 10:09 PM
    Tundrapwr16
    Rob
    California
    Right on thank you for the help.. I’ll keep you posted when I get it installed all the way and tuned.I’m not planning on leaving the head unit mounted just set tuner and remove it unless there’s something I need to do as it comes on.
  8. Feb 10, 2022 at 1:38 PM
    Tundrapwr16
    Rob
    California
  9. Feb 10, 2022 at 1:41 PM
    Tundrapwr16
    Rob
    California
    Hey Keith, question for you.my bully dog since I’m in CALI now they won’t give me any support on it.it’s not installed any longer I would like to reconnect tuner.do you have tons of knowledge on those?.
  10. Jul 27, 2022 at 11:46 AM
    Echoesineternity
    Echoesineternity New Member
    Has anyone had the invalid characters in vin error in update agent for the bullydog tuner gt+ gas? T401. I’m able to install the correct year and model of tundra, but when I go back to download and update the actual tunes I get this error in update agent. And when I go to setting my vin is definitely in there so I don’t think it’s been previous locked to anyone else.
