bullydog error 525
Discussion in 'Performance and Tuning' started by 505_sr5, Jun 4, 2019.
  1. Jun 4, 2019 at 6:28 PM
    505_sr5
    505_sr5 [OP] New Member
    jorge
    2007 red tundra sr5
    has anyone gotten the error code 525 and how did you fix it
  2. Jun 4, 2019 at 7:17 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Were you loading a tune when you got it?
  3. Jun 4, 2019 at 7:27 PM
    505_sr5
    jorge
    2007 red tundra sr5
    it goes to yellow warning screen thats says dont turn off unless instructed then you click continue then it says unlocking and then i get the error code
  4. Jun 4, 2019 at 7:28 PM
    mountainpete
    Check your battery voltage. If it’s below 12.1v put it on a charger and try again.
  5. Jun 4, 2019 at 8:17 PM
    505_sr5
    jorge
    2007 red tundra sr5
    it stays at 13.4v
  6. Jun 4, 2019 at 8:43 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You might wanna call Bully Dog while you're installing. Keith at Dirty Deeds recommended I do that.
    dirtydeeds likes this.
  7. Jun 4, 2019 at 8:57 PM
    505_sr5
    jorge
    2007 red tundra sr5
    just wondering how did you fix it
  8. Jun 4, 2019 at 11:17 PM
    Trpl7
    Trpl7 My best friend Tate
    Rob
    Washington
    Super White 07
    Partial level kit, Total chaos UCA, coach builder shackles, magnaflow ex. Tuner, SABM, complete poly bushing suspension.
    I cannot remember if I had that same code, I even had the tech on the phone when it came up. If it is the same code you will hate the repair which is pull the ECU and send it to derive system so they can plug into it and fix it. Good part is you send it out and you will get it back 2 days later. They sent shipping info so they get ASAP, they fix and return.
    Once back you reinstall and off you go.
    It sucks but they are fast.
  9. Jun 5, 2019 at 1:22 PM
    505_sr5
    jorge
    2007 red tundra sr5
    UPDATE: so i called bullydog and what i was doing wrong was when it said turn to run position i would start it but they told me do start it just turn it to on thx you guys for the help much appreciated
    dirtydeeds and Tundyfundy like this.
  10. Jun 5, 2019 at 1:29 PM
    15whtrd
    15whtrd Mr. Blonde
    Also recommended to have your truck on a charger when I initially downloading the tune.
