Bullet lined
Discussion in '2.5 Gen Builds (2014-2021)' started by Yota18, May 7, 2018.
  1. May 7, 2018 at 10:54 AM
    Yota18
    Yota18 [OP] Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    just got my truck back from the liner shop. Looks great a lot better than the Toyota insert
  2. May 7, 2018 at 11:58 AM
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    Looks great!
    Yota18[OP] likes this.
  3. May 7, 2018 at 12:18 PM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Nice. I can’t stand the plastic liner. Spray on is in the future. Right behind tires.
  4. May 7, 2018 at 12:26 PM
    Professional Hand Model
    Hand Protectors
    That does look good! I like the sprayed look better, but the drop in liner is better for banging around, loading heavy debris, sliding stuff in, spraying out gunk, etc.
    Both have their advantages. Yours looks nice! Good job.
    Boerseun, Trooper2 and Yota18[OP] like this.
  5. May 7, 2018 at 12:29 PM
    Yota18
    Stock
    Thanks I’m happy with it for sure. Bakflap mx4 next
    Ike74 likes this.
  6. May 7, 2018 at 12:36 PM
    TheBeast The Beach
    clean job !
  7. May 7, 2018 at 1:03 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    Not sure what brand mine is but looks similar to yours, mine cam from the dealer already done. I like it a lot more than the plastic liners.
  8. May 7, 2018 at 1:27 PM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Looks great!!! I hate how I got mine from the factory and nothing was prepped and all the bolt were just covered. But yours looks very clean 100x better than mine!!!
  9. May 7, 2018 at 3:23 PM
    poheller
    poheller 2018 Platinum
    Scot
    The great state Ohio
    2018 platinum
    Bullet the best.
  10. May 7, 2018 at 7:36 PM
    maharaj1
    maharaj1 New Member
    Justin
    2014 Tundra 1794 2WD
    That looks great, mine looks to have a factory spray in liner. I do not care for the drop in bed liners at all.
    Where does everyone stand on the Line-X vs Rhino Liner vs Bullet Liner, need to get my dad's truck bed done and am trying to decide. The local Rhino liner has poor reviews, I know Line-X i very popular but after seeing this one from Bullet liners I'm reconsidering.
  11. May 7, 2018 at 9:13 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    I had my bed and step bars Bullet lined. I’m very happy with it so far.
  12. May 7, 2018 at 9:48 PM
    Yota18
    Stock
    Ya I’m getting that done too when I get them also debating on having all the chrome done
    airosey[QUOTED] likes this.
  13. May 8, 2018 at 4:36 AM
    poheller
    Scot
    2018 platinum
    Well, Rino was the first spray liner which was the best as they were the only ones doing it, then came Line X which I really never cared for. So the competition started, then several years later line X bought Ryno and the owner had to sign a non compete which lasted several years. But in that time he was making a better spray liner. Once the non compete ended he started Bullet.. now you know the rest of the story. Good day.
  14. May 8, 2018 at 5:37 AM
    Looks good!
  15. May 8, 2018 at 5:43 AM
    The original guy behind Line-X sold Line-X and started Bullet.....:thumbsup:
  16. May 9, 2018 at 6:00 PM
    maharaj1
    maharaj1 New Member
    Justin
    I see, I'm definitely going to look into the Bullet liner. Looks like a very quality product and finish. Thank for the history lesson.
  17. May 9, 2018 at 8:10 PM
    Yota18
    Stock
    And they give you a lifetime warranty certificate. As long as you the original owner owns the truck.
  18. May 10, 2018 at 4:25 PM
    maharaj1
    maharaj1 New Member
    Justin
    Awesome, there are two Bullet liner retailers within 30 miles of where I live and both of them have 5 Star reviews. Lifetime warranty is also nice, my dad bought this truck brand new back in 2002 and he has no intentions of getting rid of it anytime soon so I'll have to get it in his name.
