Bulge is “bulgy like a moose” after NSV install
Discussion in '2.5 Gen Tundras (2014-2021)' started by ZappBrannigan, Feb 17, 2019.
  1. Feb 17, 2019 at 7:24 PM
    ZappBrannigan
    ZappBrannigan [OP] The mind is willing but the flesh is weak
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    As you can see it pops away from the hood and up at both corners after installing the NSV light bar. I know I’m not the only one having this problem but I can’t find a solution... has anyone come up with anything? 5781C075-2E8A-4F2A-A292-2FA32F06B058.jpg
  2. Feb 17, 2019 at 7:47 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    You'll have this issue if a cable/plug is in the way, if the bulge isn't aligned properly or if a clip is damaged. I've taken mine on and off a few times now and this happened to me only once. I had to take it off again to get it to fit properly. The other option is the light bar isn't installed properly.
  3. Feb 17, 2019 at 7:58 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    I double checked everything and it all checks out. I ended up loosenig the screws in the end brackets and it flattened out a bit but there’s still an unsightly gap.
