Bulbs to Match LEDs
Discussion in 'Lighting' started by CedarPark, Nov 10, 2017.
  1. Nov 10, 2017 at 8:11 AM
    CedarPark
    CedarPark [OP] New Member
    Dylan
    2011 5.7 2WD, 2004 TRDOR Taco
    Had a quick question
    Just installed some LED fog lights on 'El Tundy. Was wondering if anyone knew of some plug and play bulbs that would best match the color of the LEDs? I would go with aftermarket headlights entirely but trying to keep the truck as stock as possible, just trying to get a little light upgrade and a cleaner look.
    Thanks y'all!
  2. Nov 10, 2017 at 8:24 AM
    BHarry
    BHarry New Member
    Northern Nevada
    2014 BRM CM TRD
    You can match them, you just need to know what color your LEDs are. Those look like they may be close to 6000k. I’m sure you can get some great recommendations from some of the more light savvy members here.
  3. Nov 10, 2017 at 8:29 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Quick observation:
    You have only half the amount of bugs on the front of your truck as I do. To color match your lights you must ensure no more car washed until the lights are evenly coated. At that point you have to spray a thick clear coat over the bugs to hold them in place.
    Voila!!! You have matching colored lights
    This is science, right @WarEagleSteve ?
  4. Nov 10, 2017 at 8:33 AM
    Eclipsed & Floating
    Voluptuous Whitey
    In all seriousness, which fogs did you get, which color did you choose, and can you purchase the headlight bulbs from the same manufacturer? Bulbs are hard to perfectly match once you get them off cycles especially if they aren't the exact same specs
  5. Nov 10, 2017 at 8:34 AM
    CedarPark
    Dylan
    Got 'em in a trade. They look like 5500k-6000k as mentioned above.
