Built a rear bumper
Discussion in '2.5 Gen Tundras (2014-2021)' started by helidave, Oct 3, 2022.
  1. Oct 3, 2022 at 10:00 AM
    helidave
    helidave [OP] Hellacopter
    flagstaff
    2015 DC 4x4
    Main goal was to get the hitch up higher so it doesn't drag all the time. I put together a Coastal Offroad front bumper a few months ago, but this is the first time I've built one from scratch.
    First step was to make the hitch. It's all 1/4" steel and 2.5x.25 tube. Brackets bolt to the factory holes in the frame.
    Figuring out the skin. It's 3/16 steel. Tried to get some angles on there so it's not too boxy looking.
    After spending hours and hours smoothing out seams
    Primer and Raptor Liner
    Just need to paint the inside of the bumper and install it now
  2. Oct 3, 2022 at 10:01 AM
    Taco-Spike
    Two Trucks
    Nice work!
  3. Oct 3, 2022 at 10:12 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    Looks great!
    The stock hitch is really low, good job making more clearance!
    Hotwire likes this.
  4. Oct 3, 2022 at 10:27 AM
    IMXPLRN
    IMXPLRN New Member
    Rescue, CA
    2020 Tundra Limited on 35's
    Nice work. Just out of curiosity, how do you access the cross hole for the hitch pin?
  5. Oct 3, 2022 at 10:30 AM
    helidave
    flagstaff
    2015 DC 4x4
    Just reach up behind the bumper. Plenty of room to get to the pin.
    IMXPLRN likes this.
  6. Oct 3, 2022 at 10:39 AM
    JRS
    JRS New Member
    2012 DCLB
    Nice
    Did you consider notching the crossmember and receiver tubes? Would've gotten some mechanical interlocking and been able to raise the assembly up another ~1.25".
  7. Oct 3, 2022 at 10:47 AM
    helidave
    flagstaff
    2015 DC 4x4
    I didn't really want to go any higher than the bottom of the bumper because that would require some huge drop hitch. The receiver where it is now is about 7.5" higher than stock.
    AZBoatHauler and JRS like this.
  8. Oct 3, 2022 at 12:18 PM
    AZBoatHauler
    So.Arizona
    :bananadead:
    Are you taking orders?
    Occidentalis likes this.
  9. Oct 3, 2022 at 12:29 PM
    activereality
    activereality New Member
    2020 Tundra SR5 TSS Cavalry Blue
    MillerCats installed!
    Nice!! Learning to weld is on my list of things to do - what welder are you using? Do you like it?
  10. Oct 3, 2022 at 12:38 PM
    helidave
    flagstaff
    2015 DC 4x4
    no way. I like making stuff, and I don't want to ruin things by turning it into a job. Plus, I'm not a good enough fabricator to take other people money.
    I have a Hobart 210MVP. It's a pretty basic mig machine but I like it.
  11. Oct 3, 2022 at 12:39 PM
    activereality
    Nice - i have been looking at the Hobart 140, they are a highly rec'd brand for sure! Thanks man!
    helidave[OP] likes this.
  12. Oct 3, 2022 at 12:41 PM
    helidave
    flagstaff
    2015 DC 4x4
    Probably cant go wrong with that, but if you have access to a 220 outlet or think you might in the future, I would definitely recommend a dual voltage welder.
  13. Oct 3, 2022 at 12:43 PM
    activereality
    Hmm, i do have 220 outlet in my garage, so it might be worth it. I need to learn more before I pull the trigger. I try to live by the 'buy once cry once' lol
  14. Oct 3, 2022 at 12:50 PM
    helidave
    flagstaff
    2015 DC 4x4
    You can do a lot with 110, but if you can swing it, 220 is way better.
    weldingtipsandtricks on youtube has a lot of good videos and a whole series on learning mig.
    activereality likes this.
  15. Oct 3, 2022 at 12:52 PM
    activereality
    Nice - I'll check them out. Since time really isn't an issue - there is no immediate budget - makes it easier to stack little for something that would be worth it.
  16. Oct 3, 2022 at 2:11 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hell of job on that bumper! I've been seriously considering fabbing one up myself if I can get the materials cheap enough.
  17. Oct 3, 2022 at 2:12 PM
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    So you’re just going to leave us hanging without a picture of it painted and installed ?!?!!! Outrageous :quickdraw:
    Great job building exactly what you wanted!
    It’s a great way to learn and save money doing it. I also made my own bumpers.
    I love making stuff!
  18. Oct 5, 2022 at 6:14 PM
    helidave
    flagstaff
    2015 DC 4x4
    All done.
    The hitch plug is tucked up behind the bumper now.
    Jaypown, Tundra234, dorton and 2 others like this.
  19. Oct 6, 2022 at 5:05 AM
    Kernal
    Kernal New Member
    Kyle
    Charleston SC
    ‘18 4x4 4x4 DC
    I think it looks great! Similar to the sso bumper for the taco.
  20. Oct 6, 2022 at 5:10 AM
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
    Looks great to me
    :spending:
  21. Oct 6, 2022 at 5:17 AM
    Looks good. I know someone is thinking it so I'll mention it.....please post a rear shot at some point. :D
    Hotwire likes this.
