BSM and RCTA light on after mirror replacement
Discussion in 'General Tundra Discussion' started by PJR202, Jan 1, 2023.
  1. Jan 1, 2023 at 9:48 AM
    PJR202
    PJR202 [OP] New Member
    Anyone had the BSM/RCTA malfunctioning warning come up after replacing a side mirror? I've searched around online and see people mentioning it, but haven't seen a solution. I replaced my driver side glass with the exact same and the warnings didn't clear.
  2. Jan 1, 2023 at 9:52 AM
    CodyP
    CodyP Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Obviously you checked your wiring to make sure it was all hooked up correctly and plugged in fully? Pull the battery cable for a bit and reset to see if it goes away.
  3. Jan 1, 2023 at 10:01 AM
    PJR202
    Thanks. Yep. It's just three wires, one of which can only fit in one spot.
    I'm gonna try the battery later, but from the little I've read online about it, it isn't likely to work. Crossing my fingers though. I've been looking around to see if there's a diagnostic reset process, or maybe this is something that would show up in an OBD2 scan that could be cleared. If I have to take it to the dealer it'll likely negate the cash I saved by not buying a whole mirror.
  4. Jan 1, 2023 at 10:19 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I'd try the OBD scan/clear. OBD Doctor and other apps can clear them.
    CodyP likes this.
  5. Jan 9, 2023 at 6:01 AM
    PJR202
    Sorry. I saw this but didn't realize I hadn't replied. Everyone got busy and it got so cold again that I haven't checked on this yet again. Maybe the auto parts store will read and clear it. Or I have a buddy that may have a scanner. Thanks.
  6. Jan 9, 2023 at 6:17 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Yeah auto parts folks can clear them. Good luck.
