BSM and OEM Tow Mirror Mod
Discussion in '2.5 Gen Tundras (2014-2021)' started by dumbassdave, Jan 30, 2019.
  1. Jan 30, 2019 at 8:28 AM
    dumbassdave
    dumbassdave [OP] Member
    Dave
    2016 Crewmax Limited
    First off, I give credit to Safety77 on Tundratalk as it was his post that got me all set with this. If you have OEM tow mirrors, it is very easy to retain your BSM functionality. The picture with the safety pins shows the wires for the BSM light. Add a LED to your sail panel and you are all set. I used bullet crimps so I could disconnect in the future and also allow me to easily swap the wires in case I got the polarity wrong.
    Video: https://drive.google.com/file/d/1iSi3IhWsiSW2lAmEdcDldF261rTd6vKe/view?usp=sharing
  2. Jan 30, 2019 at 8:41 AM
    tinman10101
    tinman10101 Ah cha cha cha
    Tinman
    2016 MGM Crewmax
    That is a great MOD!!! Thank you for this. Kinda wanna put an LED this big when just in case the significant other decides to drive the Tundra .... LOL!
  3. Jan 30, 2019 at 9:00 AM
    dumbassdave
    Dave
    There would be no mistaking that signal!
    tinman10101[QUOTED] likes this.
  4. Jan 30, 2019 at 9:08 AM
    Harpo
    Harpo New Member
    BAD, does RCTA still work with this modification? It looks good to go, but please keep us updated on how it works in the real driving conditions.
  5. Jan 30, 2019 at 9:16 AM
    dumbassdave
    Dave
    I'd assume so as all that was done was to cut the wires that went to the LED in the mirror and relocated them inside. I'll certainly update if I notice anything out of the ordinary.
  6. Jan 30, 2019 at 1:03 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Great mod. I plan to get some tow mirrors w/ blind spot from www.1aauto.com they have them right now for around $250
  7. Feb 20, 2019 at 9:31 PM
    mac10tuna
    mac10tuna New Member
    Marc
    19 cement limited CM
    I’ve been leaning towards doing this mod myself.
    Exactly which wires did you cut?
    I know you have the photo, but I didn’t follow exactly which 2 in the pic they were.
    Thanks.
  8. Feb 20, 2019 at 9:41 PM
    dumbassdave
    Dave
    Its a bit tricky to see in the picture, but looking at the plug from the inside (which is the pic I have there), its the top right wire and on the bottom row its the 5th wire in. Sorry I can't say for sure what the wire colors were. You can always test before hand (like I did before I did any cutting) with some safety pins pushed into the connector to be sure that the LED comes on. Turn ignition on and BSM lights go on for a bit. After that you can just press BSM button on and off to trigger lights. If light doesn't go on, just switch the wires on the LED.
    mac10tuna likes this.
  9. May 14, 2019 at 12:20 PM
    Gixxertek
    Gixxertek New Member
    2019 Cement Crew Max
    So is this your 2016 listed in profile? Only asking because after installing Toyota tow mirrors(which i knew would not have BSM) now getting malfunction showing for it. Cheers.
  10. May 14, 2019 at 12:35 PM
    dumbassdave
    Dave
    Yup, on my 2016. You are getting the error because the system is sensing that there are no lights coming on. Since the light was in the original mirror, and now you have none, you'd need to wire in some lights as I did and then the error will go away. It's really not a big job at all to put a couple of LEDs in there and mount them in the sails.
  11. May 14, 2019 at 12:36 PM
    dumbassdave
    Dave
    Yes, RCTA is totally unaffected by this mod.
  12. May 14, 2019 at 1:09 PM
    Gixxertek
    Thanx. I run a motorcycle shop so I am fluent in LED. I'll play around and see if I can get it sorted. I hadn't seen anybody on the write up talking about.
  13. May 14, 2019 at 3:33 PM
    dumbassdave
    Dave
    You'll be good to go then!
  14. May 15, 2019 at 4:17 AM
    dugfur
    dugfur New Member
    doug
    2016 limited DC
    I'm a little confused...…….so you just tie into the 2 wires shown with an LED light?
  15. May 15, 2019 at 6:08 AM
    dumbassdave
    Dave
    Sure do. It's the two wires that fed the light in the non tow mirror. If there is no light connected, you get system error, if you have bsm turned on.
  16. May 15, 2019 at 11:26 AM
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    I had to do this exact thing on my '18 Limited when I did the power folding mirror mod. I got a pair of mirrors from a '12 limited, but they don't have BSM. I just installed LEDs in the sails and it works great, both for BSM and RCTA.
  17. May 16, 2019 at 9:01 PM
    Gixxertek
    Weird question but... Just installed the Toyota tow mirrors. The mirrors are uneven in distance from doors. Passenger side is swept back further. Anybody else seen this.
  18. May 16, 2019 at 9:26 PM
    dumbassdave
    Dave
    If I remember correctly, it's a bit tight getting all 3 screws in. I'd undo, give it a good shove and put the nuts back on.
  19. May 16, 2019 at 9:30 PM
    Gixxertek
    I didn't see anything under the search feature. I will double check my install when I install the BSM led to correct the "malfunction"
  20. May 19, 2019 at 3:51 PM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    I tried this on my 2018 Limited but not working. Those are the only two wires that do not have corresponding posts in the replacement mirror connector, so its got to be them, right? A quick shopping trip resulted in a couple of alligator clip wires (red & black) and a couple of very different LED bulbs, one an auto 12.8V, 1.0w amber, the other a 2w that has 120 lumens - didn't really expect it to work but the other one, I did. Where did you get your LEDs?
    gbatpdx
  21. May 19, 2019 at 4:05 PM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    Well, I got the LED to work but the alert in the dash stays on!
  22. May 19, 2019 at 4:35 PM
    :threadjacked:
    Welcome from NY.
  23. May 19, 2019 at 4:35 PM
    dumbassdave
    Dave
    Good that the lights work now. I don't have much for suggestions for the error message other than maybe disconnecting the battery for a bit to see if that clears it.
    Leo's first likes this.
  24. May 19, 2019 at 4:37 PM
    dumbassdave
    Dave
    Both LEDs? If one is out or not connected you will get the error.
  25. May 19, 2019 at 4:38 PM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    ok. I'll try that later... Bushed today. Thanks!
  26. May 19, 2019 at 4:39 PM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    Just one. Haven't replaced the other mirror yet. Wanted to be sure I wasn't going to send them back :(...
  27. May 20, 2019 at 6:14 AM
    JoeJob
    Joe
    New England
    When I did my LEDs, I had purchased just a set from Amazon, simple 5mm 12v amber LEDs. I originally wired them with resistors and they appeared to work as they lit up when I first started the truck, but as soon as the BSM or RCTA system was activated, I got the warning on the dash about a BSM/RCTA malfunction. I removed the resistors and it's been working fine since. Over a year and no issues.
    Tundra805 and Buzzeo like this.
  28. May 20, 2019 at 6:50 AM
    dumbassdave
    Dave
    Almost 100% certain that it's because you only ha e one light connected. I just had my door panel off and broke a wire on one LED. Had the error until I fixed the light.
  29. May 20, 2019 at 7:17 AM
    gbatpdx
    gbatpdx New Member
    2018 Tundra Limited
    Hmmm. There doesn’t seem to be a way to manually activate the BSM on my truck. Did the light go off before you took it for a drive? I haven’t tried driving it to activate, just used the dash menus to change the bulb brightness . Worked but didn’t affect the alert warning. I’ll try disconnecting the battery today.
  30. May 20, 2019 at 7:25 AM
    JoeJob
    Joe
    New England
    Everything seemed to be fine when I just started the truck up, but failed once I was driving around and the systems were triggered naturally. The computer is definitely sensitive to the resistance on the circuit, so you might want to make sure the LEDs you chose don't have built-in resistors.
