Brush Guard distance from front sensors
Discussion in '2.5 Gen Tundras (2014-2021)' started by 040Tundra, Dec 1, 2016.
  1. Dec 1, 2016 at 1:22 PM
    040Tundra
    040Tundra [OP] Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Hey guys. I'm going to fabricate a brush guard/pre-runner bumper type thing for the front of my 2016 CM Limited. My question is: Does anyone know how far from the front bumper sensors the tube steel needs to be so it doesn't interfere with the sensor alarm? Or does anyone know where I could look to find the info myself? Thanks in advance :notsure:
  2. Dec 1, 2016 at 1:26 PM
    cdkenne
    cdkenne Toyota Master Technician
    Corey
    KS
    2002 Tundra SR5 TRD Offroad
    285/70R17, '15 4Run Trail Wheels, Westin Shopping Cart Basher, SnapOn license plate cover that adds >50 HP
    You shouldn't have an issue so long as the bar isn't over the sides of the bumper where the sensors are. Nobody seems to be having any issues with aftermarket bull bars or grille guards.
  3. Dec 1, 2016 at 1:32 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Thanks for the quick response @cdkenne !! At first I was just going to make a bull guard but then got thinking "why stop there?" So then I had the idea to make the Bull Guard style and add some side pre-runner bars kinda like the ones N-Fab sells. So it would be a combo guard. I guess we could always hold the steel tubes in front of the truck and move the tubes around to find out when and how close I could get. I just thought one of you smart guys on here would already know. (I'll bet someone does know)
  4. Dec 1, 2016 at 1:34 PM
    cdkenne
    Corey
    KS
    I wouldn't mount anything directly in front of the sensors. Even if it doesn't set the sensor off, It could reduce its effectiveness.
  5. Dec 1, 2016 at 1:36 PM
    040Tundra
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Good point. I kinda figured that though.
  6. Nov 19, 2017 at 5:40 PM
    tcritch
    tcritch New Member
    2016 crewmax sr5 trdOR
    Did anyone ever figure out the distance or a pre fab'd one that will work with the sensors??
  7. Nov 19, 2017 at 5:53 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Why not just remount the sensors to the front of the brush-guard? I had to do this on my Armada when I had it. Just mounted them in some small electronics boxes as available from Radio-Trash and extended the wiring harnesses.
  8. Feb 11, 2018 at 11:00 AM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Did you build it?
