Brown / Rusty Substance in Oil
Discussion in '2.5 Gen Tundras (2014-2021)' started by GolfDad, Jan 8, 2023.
  1. Jan 8, 2023 at 7:58 PM
    GolfDad
    GolfDad [OP] New Member
    Daniel
    Dallas, TX
    2014 Blue Tundra CrewMax Limited
    Changed my oil today, and the oil drained from the truck had a brown / rust color on top as shown in the photo. I change the oil every 5,000 miles, and this is the first time it’s looked like this. Oil level was extreme low even though there have been no signs of leaking oil. Truck has 163k miles currently. I use synthetic 0w-20. Not sure if it’s relevant, but I just had two 600 mile trips over the holidays.
    Truck seems to be running fine and wouldn’t suspect any issue had the oil not looked like this.
    Any input on what may be happening here would be appreciated.
  2. Jan 8, 2023 at 8:09 PM
    WaterTrash
    WaterTrash New Member
    Did you check you coolant level?
    JLS in WA and FirstGenVol like this.
  3. Jan 8, 2023 at 8:20 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Exactly what I was thinking. Looks like a head gasket issue.
  4. Jan 8, 2023 at 8:22 PM
    GolfDad
    Daniel
    Dallas, TX
    I have not checked the coolant level.
    WaterTrash[QUOTED] likes this.
  5. Jan 8, 2023 at 8:25 PM
    WaterTrash
    I would start there. Let us know what you find!
  6. Jan 9, 2023 at 5:16 AM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Certainly looks like coolant is making it into the oil here.
    WaterTrash and NH 2018 Limited like this.
  7. Jan 9, 2023 at 5:59 AM
    GolfDad
    Daniel
    Dallas, TX
    Coolant level is low. Just a small amount showing in the reservoir.
  8. Jan 9, 2023 at 7:20 AM
    WaterTrash
    Sounds like you caught the early signs of a blown head gasket....sorry man
    NH 2018 Limited likes this.
  9. Jan 9, 2023 at 7:37 AM
    I hear head gasket repairs are not cheap on these. Also need coolant system flushed, potentially replace the radiator due to age and oil contamination. Sorry man, good luck with repairs.
  10. Jan 9, 2023 at 7:41 AM
    GolfDad
    Daniel
    Dallas, TX
    Appreciate the input.
    if anyone has experience with addressing this, please let me know what I’m up against here.
    Thanks.
    WaterTrash likes this.
  11. Jan 9, 2023 at 8:45 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    From Google: "The average cost for a Toyota Tundra head gasket replacement is between $2,119 and $2,405. Labor costs are estimated between $1,086 and $1,370 while parts are priced between $1,033 and $1,035."
    chugs likes this.
  12. Jan 9, 2023 at 8:49 AM
    I've heard in the neighborhood of $5G's. Like the cam towers, the process is somewhat involved and labor intensive. Head gasket failures are very rare on the boards here. If it were me, I'd do the job myself and save on all that labor. Parts, even changing out the radiator and resealing the cam towers could be sourced for under $1G. May even get a new tool out of the deal.
    WaterTrash and HulkSmurf14 like this.
  13. Jan 9, 2023 at 9:53 AM
    Jeffro22
    Jeffro22 New Member
    2013 platinum crewmax 4x4
    Damn, Sorry to see this for you. seems very rare. Keep us posted and best of luck getting fixed
  14. Jan 9, 2023 at 10:11 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    My spraynard-sense is tingling...
    HulkSmurf14 likes this.
  15. Jan 9, 2023 at 11:23 AM
    I see your DFW area and recently purchased this truck. Any chance it has undisclosed flood history?
  16. Jan 9, 2023 at 11:42 AM
    GolfDad
    Daniel
    Dallas, TX
    I haven’t noticed any issues that would lead me to think that. Any tips on something I can look for that I may be missing? And if that’s the case, how would that help me at this point? Truck was purchased 21 months ago.
  17. Jan 9, 2023 at 11:45 AM
    It’s illegal to sell a flood car undisclosed. Rusty seat brackets, rusty bolts under the hood. Milky or cloudy fluid in differentials or transmission, in addition to engine oil. If it’s possible to trace back ownership, do so and see what the story is.
  18. Jan 9, 2023 at 12:31 PM
    GolfDad
    Daniel
    Dallas, TX
    Ok, thanks for the info. I haven’t seen any issues like that. I’ve changed the oil every 5k miles since I’ve had the truck (5 or 6 times) and this the first time I’ve had an issue like this.
  19. Jan 9, 2023 at 2:17 PM
    WaterTrash
    Next step would be do a compression test to verify
    NewImprovedRon likes this.
  20. Jan 9, 2023 at 3:17 PM
    GolfDad
    Daniel
    Dallas, TX
    I dropped it at the dealership this afternoon for a compression test. Should know something tomorrow.
    WaterTrash[QUOTED] and KNABORES like this.
  21. Jan 9, 2023 at 6:38 PM
    WaterTrash
    Let us know what you find out, please!
    I have 60k on my 2017 and I am in the process of doing tests for possible head gasket issue as well after finding my reservoir and radiator low.
  22. Jan 10, 2023 at 11:00 AM
    GolfDad
    Daniel
    Dallas, TX
    Dealer tested compression on coolant system and cylinders and the readings were normal. They do not know what caused the issue. Suggested I check / change the oil after a few hundred miles again to see what it looks like.
  23. Jan 10, 2023 at 11:04 AM
    AZBoatHauler
    So.Arizona
    I’ve found my overflow low a couple times - first time I wasn’t able to trace it - second time it was leaking around the hose clamp where the lower rad hose mates to the thermostat/waterpump. Look for dried coolant around all the connections.
  24. Jan 10, 2023 at 11:23 AM
    Knox_Tundy
    Knox_Tundy New Member
    Knoxville, TN
    Low coolant, small pin hole leak around the hose fitting, & or radiator is common with these. A lot of threads on here where people have no idea where their coolant is going.
  25. Jan 10, 2023 at 11:28 AM
    Might be worth, if you still have some of the oil, doing an oil analysis. Could the oil just be frothy from a recent drive? Pan was dirty prior to draining oil? Great news on the compression check though!
    FirstGenVol and AZBoatHauler like this.
  26. Jan 10, 2023 at 11:57 AM
    WaterTrash
    Well my radiator is pressurized after the truck sits for 24 hours as well. I'm getting a c02 tester delivered tomorrow to check for exhaust gasses
  27. Jan 10, 2023 at 11:58 AM
    WaterTrash
    That's good news. Not sure where to go from here. Low oil, what looks like water in the oil, and low over flow...hmmmm
  28. Jan 10, 2023 at 4:45 PM
    WaterTrash
    Been doing some reading on 5.7 head gasket failures. Seems pretty uncommon. I'm seeing mileage vary wildly from 60k-190k miles. Also seeing that it is pretty difficult to confirm a head gasket issue until it gets pretty bad.
    I would follow the advice of the dealer and keep a close eye on/document fluid levels for changes.
    WILLINH likes this.
