Broken U Joint
Discussion in '1st Gen Tundras (2000-2006)' started by dawg4x4, Nov 8, 2019.
  1. Nov 8, 2019 at 1:59 PM
    dawg4x4
    dawg4x4 [OP] New Member
    2005 Tundra - Single Cab, extended bed, 260K miles
    Hey everyone,
    For the past week or so I have had a pretty bad rumble when accelerating. Finally got under the truck to look and looks like one of the U joints snapped and has started wearing in to the double cardon. My question for the experts: is it worth doing yourself or just bringing to a mechanic? My truck is a 2005 Tundra, 4wd, 260k miles on it. Thanks! Pics below:
    HKcTKKmmTbuzuKjlM%ov5w.jpg Xk722lydSa+aDEwYU+hbwA.jpg NfKbGwMHTtGONXvlSoclGA.jpg
  2. Nov 8, 2019 at 2:03 PM
    dawg4x4
    And these 2 pictures are after I put it in reverse just enough to shift the weight off the u-joint4Q9Z+SIXRwGYuJUqxwBxeA.jpg kh9EINcTSFqZWtlZt1i0%g.jpg
  3. Nov 8, 2019 at 2:08 PM
    Glad that didn't fail while driving! Scary to think about it.
    Multiple factors to consider:
    1 - Is this your only mode of transportation?
    2 - Can you afford for it to sit for a day or two if you attempt this and it's more than you planned for? (What's your skill level as a wrench monkey?)
    3 - Do you have a mechanic/shop that you trust?
    4 - Do you have the spare $$$ to make it somebody else headache?
    Personally, I hate messing with drivelines, my mechanic skills are weak, and I only have one vehicle, so this would be going to a shop for me.
    YardBird and Pinay like this.
  4. Nov 8, 2019 at 2:18 PM
    dawg4x4
    I have an old jeep that I practice most of my wrenching on that I can use to get around if I attempt this. My level of wrenching is fairly basic, mostly what I have learned on youtube. On my Jeep I've done my own lift with junk yard parts, brakes, all the regular maintenance, etc. Certainly have never done this before but I have learned plenty on youtube to get me by thus far! One of my fears is bringing it to a shop and them charging me a bundle for this (and 10 other things they might find wrong) on a truck that already has 260K miles on it. But you definitely bring up some great points and it is good to hear it from someone else.
    Thanks for the input!
    GODZILLA likes this.
  5. Nov 8, 2019 at 2:32 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    There's a couple posts on the forum about the double cardon joint. None of which are encouraging. Short answer, you cant buy just the joint new anywhere. Even if you could, removing the old joint from the driveshaft is a pain due to the geometry of the cardon joint. It's not just two universals back-to-back. There's a ball similar to a steering knuckle ball joint that is in between the universals. All three move in concert with each other which prevents just banging out the universal cups.
    I think you need an entire rear driveshaft assembly which will have the cardon joint already installed. Please update the thread as you solve this problem as there is no recent info regarding this repair.
    bmf4069 and speedtre like this.
  6. Nov 8, 2019 at 3:05 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Like @remington351 said, you need a new shaft. Or at the very least a shop that would chop the old yoke off, weld new, and balance the shaft.
    If it's your only vehicle pull the whole driveshaft and put it in 4wd until you get it fixed.
  7. Nov 8, 2019 at 3:21 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
  8. Nov 8, 2019 at 3:57 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    The joints aren't why we're saying replace the shaft. It chewed a groove in the yoke, no shop is going to install joints in it.
    02goes likes this.
  9. Nov 8, 2019 at 5:05 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    True but a drive line shop will reuse the good parts like the tube, rear yoke and the cardan housing. That save's quite a bit of money. This custom shaft cost me $400 to be built. They reuses the end yokes and replace the tube for $100.
    ColoradoTJ likes this.
  10. Nov 8, 2019 at 6:28 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Got it. I didn't see that particular damage. (I must have skimmed through :rofl:)
    Yeah, I would replace that part of the shaft.
    I run a woody..
    http://www.4xshaft.com
    Good price. Well built.
    Could pick up a used one from a yard also.
  11. Nov 8, 2019 at 6:46 PM
    Batel
    Batel New Member
    2019 Tundra SR5 TRD Offroad
    Sure looks like that yoke is toast. They're pricey. Reman driveshaft may be your best bet. The driveline shops in my area have pretty good turnaround usually but a quality reman is the quickest. Most of the shops I used to deal with wouldn't touch those doubles.
  12. Nov 8, 2019 at 6:49 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    I would take it a driveline/driveshaft shop and tell him to get rid of the double Caden joint and install standard joint with slip joint spline. Or at least get their professional opinion on your options.i had a custom driveshaft made for my truck to eliminate vibrations and driveline failures
    YardBird likes this.
  13. Nov 8, 2019 at 7:06 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    I second the motion.
  14. Nov 8, 2019 at 7:24 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Look at how dry that Trunnion is. :eek2: Do 1st Gens have Zerks, or are they sealed units? Haven't looked at what my 19 has yet, but I've always been a big believer that a sealed cup is far superior to the ones that have Zerks. Just my 2 cents of course. ;)
  15. Nov 8, 2019 at 7:34 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Yeah, doesn't look lile those u joints have been greased in a very long time...
  16. Nov 8, 2019 at 7:47 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
    I wouldn't rid of the double cardan without measure the angle of the transfer case output shaft in relation to the center line of the rear diff pinion shaft. If they are aren't parallel a double cardan is required.
  17. Nov 8, 2019 at 7:54 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Years ago I had an F150 that I broke my driveshaft on the side of the road a few miles from home. I got picked up, went home and got tools, pulled the driveshaft, drove the truck home in FWD & had the driveshaft fixed.
    Good luck.
    thearborbarber likes this.
  18. Nov 12, 2019 at 7:58 AM
    dawg4x4
    Thanks for all the advice thus far! So out of curiosity, I took my rear driveshaft off and drove to the Toyota dealership to see about a repair through them. They wanted 1900 for the repair and offered me 500 to take the truck off my hands! Crazy. So now I am on my way to a pull-a-part to see if there is anything worth salvaging before going to a driveline shop. Below is a video of the shaft off the truck where you can see really how close it was to falling off while driving!
  19. Nov 12, 2019 at 8:11 AM
    Professional Hand Model
    Hand Protectors
    Try finding a Heavy Truck Shop. They see this stuff all the time on Big Rigs. Since you have the shaft off already its a no brainer for them. Probs a few hundred with labor and new Spicer joints total.
    FrenchToasty likes this.
  20. Nov 12, 2019 at 8:48 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That's a banana sandwich price considering the list price from Toyota for a complete shaft is only $1500.
    You could see if anybody has this one in stock.
    https://www.dormanproducts.com/p-68546-936-719.aspx
    dawg4x4[QUOTED][OP] likes this.
  21. Nov 12, 2019 at 11:38 AM
    dawg4x4
    After striking out at two pull a parts, I’m gonna try to find this. Thanks for the link. That should save a lot of headache!
  22. Nov 12, 2019 at 12:51 PM
    SC T100
    SC T100 New Member
    2005 Toyota Tundra Double Cab 4WD
    Rancho Quicklift/RS9000XLs, Rancho rear 1.5" blocks with RS9000XL shocks in rear, SuspensionMAXX extended sway bar links.
    Try car-part.com too.
    dawg4x4[OP] likes this.
  23. Nov 12, 2019 at 12:53 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    My rear drive shaft just broke on Friday night. Somehow the nut that holds the two piece shaft together at the double cardon got loose and stripped the last couple threads off and then ground down the splines. I just ordered a new drive shaft from https://www.wholesaleimportparts.com/Toyota_Tundra_Driveshaft_2005.php because they seemed well made and with 275k miles on this truck I figured a new drive shaft was worth it rather than trying to get this one repaired.
    My double cardon looks fine and you may be able to use it? Id be more than happy to send it to you if you want to cover the shipping. I am assuming they are the same between our trucks.
  24. Nov 12, 2019 at 1:38 PM
    Hand Protectors
    Let us know the price once you locate that bit of info. Went to the website, but lots of hoops to jump for price?
  25. Nov 12, 2019 at 1:46 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Amazon and Summit Racing list it for a little under $600.
  26. Nov 12, 2019 at 1:54 PM
    Hand Protectors
    Not bad! My heavy truck center quoted $180 for all new Spicers with labor. Guy said he has done quite a few 1st Gen Tundras and knows they are a pain due to the Doublé Cardán. The catch was I had to pull it and reinstall it. Wasn’t interested.
  27. Nov 12, 2019 at 6:08 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Afraid to mess up the money makers?
  28. Nov 14, 2019 at 4:21 PM
    dawg4x4
    Wow I certainly appreciate the offer seth419! Very nice thing to do. But after some more searching thanks to SC T100 suggesting the car-part.com, I found a junkjard 50 miles away that had an 06 full driveshaft which was a direct fit. Already bolted it back on (after greasing all the zerks) and the Tundra is driving like new again. Spent 200 at the junkyard for the used driveshaft in pretty good condition. Just didn't have it in me to spend 600 on a new one.
    Thanks again everyone for the support! This is an awesome community.
  29. Nov 14, 2019 at 4:22 PM
    Hand Protectors
  30. Nov 15, 2019 at 4:51 AM
    SC T100
    SC T100 New Member
    Glad to hear it worked out! Don't forget to do a few pumps of grease into the slip yoke at each oil change, too. Should keep the driveline bump gremlins away.
