Broken temperature control switch
Discussion in '1st Gen Tundras (2000-2006)' started by Bholmes, Sep 28, 2019.
  1. Sep 28, 2019 at 4:56 PM
    Bholmes
    Bholmes [OP] New Member
    2000 green tundra trd
    hey guys, the temperature control knob broke in my truck. Taking a further look it seems to be a deeper problem with how it attaches to the wire that adjusts the temp. The wire is stuck too and won’t go in to the hot setting, unfortunate cause Montana is getting its first snow this week!
    Any ideas on how to fix this or what the parts are called?
  2. Sep 28, 2019 at 5:52 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    @Roman who is a member here from CoolSprings Toyota Parts Dept is who I would be checking with if I had this problem. Of course I would also head up the road to Raceway pick a part for a used one more than likely.
    Below is the parts layout of those switches from CoolSprings Toyota Parts.
    https://parts.toyotaofcoolsprings.c...ra--limited--4-7l-v8-gas/electrical--switches
    Sounds like it's going to be a big jacket week for you folks as we swelter in the 95 deg heat :(
    Roman likes this.
  3. Sep 30, 2019 at 11:01 AM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    If it is on the back side of the heater controls, it is going to come with the heater control assembly from Toyota. I'd find a local pull a part, and grab what you need out of it.
