Broken Rear Diff
Discussion in '2.5 Gen Tundras (2014-2021)' started by tundras12, Jul 14, 2025 at 12:01 PM.
  1. Jul 14, 2025 at 12:01 PM
    tundras12
    tundras12 [OP] New Member
    Monday
    Anyone had rear diff go out? I have only 75k miles and clunking noise from rear end when shifting from D to R and R to D, also same clunking noise when letting off gas and then hitting gas again. Any suggestions or similar problems?
  2. Jul 14, 2025 at 1:54 PM
    Toney198
    Toney198 New Member
    2014 1794 4X4
    I would look at the U joints first.
    AZBoatHauler, Wynnded and texasrho83 like this.
  3. Jul 14, 2025 at 2:01 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    sounds to me like an excuse to get some 5.29s
    snivilous, sudobash and TOYOTARIG like this.
  4. Jul 15, 2025 at 6:55 AM
    tundras12
    Monday
    Replaced the rear u-joint yesterday and it was definitely broken, but still making clunking noises, but a little less as loud.
  5. Jul 15, 2025 at 12:42 PM
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    I’ve seen the cross in wallow out the carrier causing the clunk… drain your diff fluid and see what comes out.
  6. Jul 15, 2025 at 12:47 PM
    tundras12
    Monday
    Drained it and it was flakey and no chunks.
  7. Jul 15, 2025 at 1:04 PM
    Js18tundra
    It’s p
    might be the cross pin then. Put it in park and try to spin the drive shaft by hand at the pinion flange, you can tell if it’s a u joint.
