Broken leaf springs and rear axle assembly swap.
Discussion in '2nd Gen Tundras (2007-2013)' started by armozo, Sep 4, 2020.
  1. Sep 4, 2020 at 8:12 PM
    armozo
    armozo [OP] New Member
    Pacific North West
    2014 Tundra CrewMax 1794
    Hi all, I am new to the forum and was wondering if you could advice me.
    I found out today that the second from the bottom leaf spring is broken off in both sides. The forward half. I want to restore OEM feel and look and I have access to a 2019 tundra set of leaf springs. Do you guys think they will fit?
    Lastly I have access also to the entire axel from the 2019. Does it just bolt on? I believe my 2007 limited has the same gear ration 4.30. My axel bearings are done and it is cheaper to by this axel assembly than pay to rebuild the axel bearings.
    Thanks in advance for our advice.
