Broken Front Bump Stop
Discussion in 'Suspension' started by PhoenixSR5, Jun 24, 2024.
  1. Jun 24, 2024 at 1:26 PM
    PhoenixSR5
    PhoenixSR5 [OP] New Member
    Brandon
    Gilbert, Az
    2016 Tundra SR5 work in progress
    Front: King 2.5 EXT RR, Freedom Offroad Uniball UCA, Sway Bar Delete, BMC and Pinch weld mod. Rear King 2.5 RR shocks, Icon AAL. Fuel Zephyr 18x9 +1 w/ Dirty Seven Maxxis RAZR MT
    I had installed the Coachbuilder bump stop extensions when I did my front suspension. In the process of removing them the stud from both front/fronts broke off. I left the front/rears installed so I had some sort of protection. I plan on swapping them for Durobumps. The instructions for the Durobumps say to only replace the front/rears and leave the stock fronts in place. My question is can I just leave the fronts off completely to avoid the extra headache of drilling them out or will end up causing more problems for myself?
  2. Jun 24, 2024 at 1:45 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You're still going to want to go through the trouble of extracting that broken stud, and replacing that bump. I know that the rear is going to engage first, but you need a bump up there for the really hard run-ups.
    RobertD and des2mtn like this.
  3. Jun 24, 2024 at 1:52 PM
    PhoenixSR5
    Brandon
    Gilbert, Az
    That's what I was thinking. It's so hard to get motivated for that when it's 110 outside lol.
  4. Jun 24, 2024 at 5:42 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I agree with Colton.
    As a compromise, maybe don’t jump it till it cools down and you can fix them up.
  5. Jun 24, 2024 at 5:45 PM
    PhoenixSR5
    Brandon
    Gilbert, Az
    No jumping in its future. Not quite there yet lol.
