Broken Door Bolt
Discussion in '1st Gen Tundras (2000-2006)' started by JMarv7, Feb 17, 2024.
  1. Feb 17, 2024 at 9:49 AM
    JMarv7
    JMarv7 [OP] New Member
    Montana
    2001 Tundra SR5 RC (or single cab)
    Tundra SR5 4x4 with 4.7 V8 - 8 ft camper shell with 3 rows of LED lights - Adjustable rack above camper shell - 8 ft rubber bed liner - heated seats - power door locks - Bluetooth radio with large screen - Backup camera - LED fog lights - LED separate rear facing lights - 17 in Toyota alloy wheels, currently on BF Goodrich KO2 off road tires - Skid plate - New shocks - Rubber mats - Front end lift 2" (to make truck level + room for bigger tires) - Added leaf spring for additional towing capacity
    This is my first post (sorry if it is not done correctly).
    I found a broken bolt on the bottom left-hand side of my driver's door. I pulled back the plastic panel and you can't access the bolt without removing the panel. It looks like it might serve some "dampening" function for quiet driving. I am not really sure. The bolt is stuck in a rubber, spring-backed sort of thing. Doesn't seem like you can access it unless the entire door panel is removed, but even then the bolt is through the metal frame, not the plastic trim. I attached some pictures.
    Any help/explanation would be great! I want to avoid some loose metal rattling around in the door while driving.
    Thanks!
  2. Feb 17, 2024 at 3:10 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    I believe that is the lower bolt securing the window track
    whodatschrome, 2mchfun and 1lowlife like this.
  3. Feb 17, 2024 at 3:51 PM
    2mchfun
    /\/\This, might be able to carefully take the bolt from the opposite door without the window frame falling so you can match up a replacement. I'd do it with the window halfway down to allow for a hand grip on the glass if needed to shift the position of the frame upwards enough to align it for replacement of the bolt. If you can see the bolt is really snapped off, you might be able to get it backed out with a slightly smaller diameter left hand drill bit without taking the panel off the door. The question would be...why did it break in the first place? Check the other side before it becomes loose and breaks too.
  4. Feb 17, 2024 at 10:50 PM
    whodatschrome
    whodatschrome New Member
    North of North Plains, Oregon
    lots of dents
    No doubt it’s a M6x1.0 bolt. Probably somewheres around 20~25mm long? Torque spec for a M6 bolt is usually just 10Nm. It wouldn’t take much to snap one of those bolts with a 3/8” drive wrench. There’s probably a 99% chance that you’ll have to remove the door panel to remove the broken off fastener. It will probably be fairly easy to unthread it with a pair of needle nose vice grips. If you got mad skills and great luck, you might be able to unthread it without removing the door panel. My thought would be to unroll the window until it’s all the way down (so that the metal window track isn’t as floppy), then try using a left hand drill bit to back out the bolt. Homo Depo/Lowes also sell something like a SPEED EXTRACTOR. The extractor does work really well, but it might not work well in this particular instance though.
  5. Feb 18, 2024 at 4:56 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    See the rust and flaky paint? Perhaps some sort of impact was involved.
  6. Feb 18, 2024 at 6:53 AM
    2mchfun
    Yes, I noticed! Looks like someone or the wind might have closed the door pretty hard on something in the way and that something was probably the seatbelt clip. Just plain bad luck that it managed to align exactly right to break the bolt. Any story behind the damage OP?
  7. Feb 18, 2024 at 7:10 PM
    JMarv7
    Montana
    Hi Everyone! Thanks for the helpful comments on this. You are right that it is the bolt securing the window track. I found the diagram in the FSM manual (page 465 if you are curious). I will almost certainly have to take the panel off, and even then it will be a pain to get the bolt out. My weather is currently in the single digits so I am going to hold off on doing any tugging on the plastic for the time being.
    I am unsure of how the damage occurred -- probably a seatbelt malfunction. The truck is basically brand new to me so I am still getting to know it.
    Thanks again,
    Here is a screenshot (below) from the manual if you were curious.
    2mchfun likes this.
  8. Feb 18, 2024 at 7:29 PM
    2mchfun
    Hit that dude with some penetrating oil spray, pop it in the middle with a good center punch to make a divet, hit with an 1/8" left hand drill bit at slow speed and you should be able to get it out enough to either grab it with a pinch tool or possibly even a magnet. Worth a shot IMO, but obviously do as you wish. That said, if you do take it apart, spray the track, latch, and locking mechanisms with some silicone lubricant while you are in there tinkering.
  9. Feb 19, 2024 at 8:43 AM
    socomoby
    socomoby New Member
    2006 DC V8/2WD SR5 LSD
    Confirmed. It holds the window rail. Had to remove it recently to fix the door latch
